C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
cam swap
Old May 4, 2020 | 10:16 PM
russ472's Avatar
russ472
Default cam swap
middle of doing a cam swap and found my timing chain tensioner had broke. The new cam is converting to a 3 bolt sprocket and the kit came with a spacer that goes between where the old tensioner goes? does this new piece take the place of the old tensioner?
Old May 5, 2020 | 10:24 AM
Spaceme1117's Avatar
Spaceme1117
If it looks like the below picture, then yes this take the place of the tensioner. It is a dampener. Very common for people to use this in place of the tensioner as the tensioner does have a relatively high failure rate.
Old May 5, 2020 | 10:30 AM
CI GS's Avatar
CI GS
Yes, that’s an LS2 type timing chain “tensioner” which is more durable that the later model spring tensioners.
Heres how it looks installed:
Old May 5, 2020 | 12:25 PM
russ472's Avatar
russ472
yup, that is exactly what came with the kit. Thanks!
To cam swap
