C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Educate me on E85
Old Sep 20, 2020 | 03:57 PM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
Default Educate me on E85
I had posted another post thinking of a cam swap on my Supercharger 2013 GS. But now, I’d like to know more about E85 Fuel.conversion. Is there power to be had with E85 as opposed to swapping in a cam? My GS with just an A&A V3Si trim and a set of Kooks long tube headers is already making 600+rwhp. I’m just wondering what else I can do just to add maybe another 50rwhp. Please suggest and educate me the pros and cons of E85. Thank you in advance.
Old Sep 20, 2020 | 05:53 PM
russ472's Avatar
russ472
E85 definitely makes a noticeable difference on forced induction vehicles. you can run more timing and also have the additional safety of the additional octane.
Old Sep 20, 2020 | 11:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There’s probably some power to be had. E85 is basically cheap high octane fuel. That’s the upside. The downside is it has about 30% less energy per gallon than gasoline, so you need a fuel system that can supply an extra 30%, more or less and ideally a flex fuel sensor so the computer can adjust for how much ethanol is in your fuel automatically.
If your current tune is knock limited then yes, adding e85 and bumping timing will def get an increase. I do it all the time when I tune CTS-V’s. 50rwhp isn’t unusual on those with some basic mods.
If you aren’t knock limited then it’s still a lot safer since knock is really what kills these engines and you never know when you’ll get a bad tank of gas.
You’d also be in a good position for a smaller pulley if you ever wanted to do that
Old Sep 21, 2020 | 09:50 AM
ls1wolf's Avatar
ls1wolf
At 11psi of boost with a tvs2300, I was at 671 on 93 pump. Went flex E85 and ended up with 750whp.
it’s unreal what a different gas pump nozzle can do for ya.
Old Sep 21, 2020 | 11:54 AM
VVVROOMTX's Avatar
VVVROOMTX
If you have the availability of E85 at a pump in your area then i highly recommend you get the flex fuel sensor installed. Its just too easy to pass up.
you can still put 93 in your car anytime you want and the flex fuel sensor will automatically adjust.
E85 on a boosted car gives large gains, if you are making 600hp adding e85 will put you right at or just about the 700RWHP mark.
Old Sep 22, 2020 | 03:10 PM
LOURDESBELLE
Thats Amazing and very impressive if that much gains are attainable! Is this a “seat to the pants” you can feel difference? If so, I will pass on cam swap that I initially planned.
Old Sep 22, 2020 | 03:16 PM
VVVROOMTX's Avatar
VVVROOMTX
Oh defiantly you'll be able to tell immediately. You put up mid range torque on E85 as well. I recommend getting a DSX flexfuel sensor kit and a dashboss so you will be able to see your ethanol content. Do you have a wideband?
Old Sep 22, 2020 | 03:30 PM
CI GS's Avatar
CI GS
I went from running ~6.3x @ 111 to 6.1x @ 114 (in the 1/8 mile) just by switching from VP MS109 to VP X85.
So the gain between 93 octane pump gas and E85 should be even greater.
Go vegan...
Old Sep 23, 2020 | 06:04 AM
scottg's Avatar
scottg
I got about 65 more ponies by switching to E85 and flex fuel in June of this year. went to 691rwhp. The torque also went up to 630 witch I could could notice also. On 60 degrees days up here in Minnesota I'am sure I'am over 700 just can't get the traction. I will address that next spring. Hope this helps.
Old Sep 23, 2020 | 09:42 AM
Gotit4cheap16's Avatar
Gotit4cheap16
Gained over 100rwhp by adding E85
Old Sep 23, 2020 | 10:44 AM
LOURDESBELLE
Wow, more Amazing results! That’s insane. How about long term use of E85, any downside? I’d like to also mention that I don’t race the car at the track. But it’s nice to know that it will be making over 650rwhp. It’s more of a fun in the street, open back roads, and highway pulls, spirited driving and of course long weekend trips with the wife. When it’s time to store the car for the winter, any precautionary measures?
Again thanks for all the suggestions😊
Old Sep 23, 2020 | 11:05 AM
Spaceme1117's Avatar
Spaceme1117
If I am not mistaken, to run E85 you need to make sure that your fuel pump and injectors can keep up. E85 doesn’t have the energy density of gas so you need to flow more E85 to make the same or more power.
Other than that, all you need is an E85 sensor and the tuning for it.
Old Sep 25, 2020 | 02:04 PM
VVVROOMTX's Avatar
VVVROOMTX
To run E85 you will need:
A boost a pump or larger fuel pump (I recommend the AA corvette kits)
bigger injectors (FIC is a really good brand and i think 850s for your power would be ok)
Flex fuel sensor
tune
Old Sep 26, 2020 | 02:52 PM
Chiselchst's Avatar
Chiselchst
My bet is you will get your 50hp no problem, and likely be 'safer'...
I gained ~90 going from 91 octane to E85...(dyno'ed on both)
Old Oct 6, 2020 | 12:57 PM
LOURDESBELLE
Flex fuel sensor
tune
The car already has BAP, Deka 80#’s injectors. So all it may need now is a bigger external fuel pump, a Flex fuel sensor, and of course a tune update.
Old Oct 6, 2020 | 08:41 PM
m60gov20's Avatar
m60gov20
Hoping to try mine out this weekend. Drioping a 1/2” on blower pulley and adding flex fuel.
Old Oct 7, 2020 | 01:32 AM
Chiselchst's Avatar
Chiselchst
That should give you a triple digit gain minimum...what ever size they are now..
Old Oct 7, 2020 | 06:25 AM
m60gov20's Avatar
m60gov20
That’s what I’m hoping for. It’s an Eforce with a 3.5” pulley I made 530 whp on a mustang dyno before I did headers.
Old Oct 8, 2020 | 01:51 AM
Chiselchst's Avatar
Chiselchst
Exactly where I was (537whp) prior to switching to E85...
To Educate me on E85
