C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
4 corner steam vents...
Old Oct 2, 2020 | 12:09 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default 4 corner steam vents...
Are they worth the time/$? How many are using them? Intake is off and now would be a good time for them....
Old Oct 2, 2020 | 08:41 PM
EnginerdVT's Avatar
EnginerdVT
I think it's made a difference, mostly in bleeding the system (much easier to fill the damn thing)... I didn't do a 1:1 to see if temps came down but physically they make sense as well compared to block offs that would store air pockets.
Old Oct 2, 2020 | 08:42 PM
EnginerdVT's Avatar
EnginerdVT
By the way, if you need a kit, I have one for mine but had to swap to a different kit since mine can't fit under the intake anymore... let me know, its basically the block, some lines and the fittings for the block.
Old Oct 2, 2020 | 10:26 PM
C U IN REARVEIW
Pics? Price?
Old Oct 2, 2020 | 11:02 PM
EnginerdVT's Avatar
EnginerdVT
Originally Posted by C U IN REARVEIW
Pics? Price?
Will send pics in the morning. Let me see if it's all there and I'll PM you a price shipped.
Old Oct 3, 2020 | 12:27 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I think I just used the steam vent tube off some other model for the rear and tied it into the cooling system instead of doing the fancy billet adapters with hoses and blah blah blah, too complicated. I think it's worthwhile if you're going to be doing long pulls
Old Oct 3, 2020 | 07:39 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I have no data to back it up, but I think 4 corner vents are a small piece of the puzzle that allowed my car to never run hot like so many do. I would do them if its apart anyways.
Old Oct 3, 2020 | 08:38 AM
Spaceme1117's Avatar
Spaceme1117
If you can fit steam vents on the rear and tie them in, it is never a bad idea.
But on my 2011 GS, the LS3 heads’ rear steam ports are not drilled. So for me I would need to pull the heads to do this. Just not worth it for me.
Old Oct 3, 2020 | 09:53 AM
CI GS's Avatar
CI GS
Do you need it? Maybe not. But if it helps to keep those rear cylinders from running hotter by bleeding any trapped air out of the water jackets, then it was worth it for me. I used the Earls kit on mine. Not the cheapest, but it allowed me to tuck the hoses away so that I didn’t have to worry about clearance when I reinstalled my supercharger.
EDIT: I believe my stock heads were plugged too (although that should be easy to fix with a small angle drill) but when I changed heads to the GM LS3 CNC versions, those came without the plugs.
Old Oct 3, 2020 | 04:18 PM
C U IN REARVEIW
I just torqued heads down ....literally....would I need to pull them to drill hole?
Old Oct 4, 2020 | 09:29 PM
Last 1's Avatar
Last 1
Here what I had to do in order to run steam vent with a MSD ls 7 intake .and yes
I could have got bye cheaper with ls6 kit
Old Oct 12, 2020 | 09:01 AM
C U IN REARVEIW
you have an LS2 correct? 2005? I pulled the rear blocker plates and ran a borascope down in them....so they are driled correct? Or are the blocked somewhere else in the head I couldn't see ?
Old Oct 12, 2020 | 09:17 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes, they are open from the factory on ls2’s
Old Oct 12, 2020 | 10:33 AM
C U IN REARVEIW
Great,thanks!
Old Oct 13, 2020 | 08:41 PM
SteveJewels's Avatar
SteveJewels
@Nursing Nevada
Where do you find could do a conversion?
Old Oct 13, 2020 | 09:40 PM
C U IN REARVEIW
Originally Posted by SteveJewels
@Nursing Nevada
I ordered a kit from trick flow
To 4 corner steam vents...
