C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
DSX Flex fuel sensor fluctuating?
Old Oct 13, 2020 | 06:00 PM
m60gov20's Avatar
m60gov20
Default DSX Flex fuel sensor fluctuating?
I just installed a DSX flex fuel sensor and the reading is all over the place. It still has 93 pump gas in it. At one point it went to 100% ethanol content. Anyone experience this issue before?
Old Oct 13, 2020 | 07:47 PM
EnginerdVT's Avatar
EnginerdVT
Picture of your install? Mine is not installed in the preferred way and does fluctuate some because it's installed vertically and goes straight down into a long horizontal run to the return in the back of the car down the rocker. Dave at DSX warned me that it might do that at WOT as there wasn't a lot of return pressure and I didn't form a loop or a "trap" similar to a drain to ensure we kept air out of there and always had it full of fuel/E/whatever. I intend to fix that but it's not fluctuating that much and is reasonable so far with WOT dyno pulls.
Old Oct 13, 2020 | 08:08 PM
m60gov20's Avatar
m60gov20
Mine is now reading 100% ethanol all the time. It still has pump 93 in it. I have an 08 base model. Pinned #40 on the black connector. My sensor is mounted by the brake booster at the feed line at the firewall to a t, one line feeds the back of the passenger fuel rail. The outher goes to the flex sensor then to the back of the drivers fuel rail. I I still have the line at the front going from rail to rail.
Old Oct 14, 2020 | 10:55 AM
ls1wolf's Avatar
ls1wolf
You don’t have a good connection. Make sure the pin is pushed ALL the way in. Mine did same thing until it was installed correctly.
Old Oct 15, 2020 | 09:16 AM
m60gov20's Avatar
m60gov20
After a couple emails with Dave at dsx I figured out my issue. We thought i didn’t have the pin at the ecm seated correctly. I took that apart a few times. It started workink for a little bit then messed up again. Turns out I removed the t fitting before the sensor i was using to feed the back of the passenger side fuel rail. It started reading a lot more consistent and all seems well. I emailed Dave again and he said the t was likely causing the fuel to aerate. Caussing the sensor to read 100% ethanol at times.
Customer service at DSX Tuning is excellent!
Old Oct 15, 2020 | 09:43 AM
EnginerdVT's Avatar
EnginerdVT
Agreed, Dave has been really helpful.
To DSX Flex fuel sensor fluctuating?
