C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Another P/D vs Centrifugal Thread
Old Jul 15, 2021 | 03:38 AM
rajahhindi's Avatar
rajahhindi
Originally Posted by chuntington101
If you are worried about temp issues there are ‘bolt in’ air to water solutions out there for centri blowers. Not cheap but would block the rad the same as a PD (as effectively it’s just a HE). Worth a thought!
the Cordes solution is really neat if you aren’t using the fog light area for other coolers: https://www.corvetteforum.com/forums...-900-rwhp.html
May i ask what car you own and mods? You are always interfering with what i call ****! Internet guru?
Old Jul 15, 2021 | 09:43 AM
CI GS's Avatar
CI GS
I have to shake my head when I see people still saying that “PD” blowers have more heat issues than centrifugal setups on C6s. There are hundreds of post on this forum alone documenting the struggles that many centrifugal setups have had with serious overheating problems, with people adding massive aftermarket radiators and high$ fans, moving their oil coolers behind the fog lights, cutting the front bumper/frame, spacing out their intercoolers, etc. And it’s not confined to the 800-1200whp “Big Dick Daddy” setups either.
But, I have yet to see one thread about either a Edelbrock or Heartbeat setup overheating. Hmmn, something’s not making sense here… Yeah, I know, no doubt that’s because our setups don’t make enough power.
I’m running a stock fan, with my $50 Hayden ATF cooler stacked between the A/C condenser core and the radiator, with the standard Magnuson H/X up front. I have DeWitts rad, but that didn’t do anything for me either, other than give me peace of mind that I wouldn’t have to worry about the stock plastic cracking open, which would probably never happen anyway. I added a 160* thermostat way back when everything else was stock, and that only marginally affected my cooling, since back then the fan settings were stock too.
I’ve done all kinds of **** to my car to try to get IATs lower, some that worked and others that couldn’t. Unfortunately, I can’t spray meth on my IAT sensor, so I can’t brag about having lower than ambient IATs. But my engine coolant doesn’t boil, and my ATF temps usually run slightly lower than the ECTs.
I have many hours of datalogging at the track and on the road, which document that my ECTs have not gone over 210* in heavy traffic, and I’m sure my ATF temps haven’t been over 200 degrees since I added the ATF cooler.
On the street, my IATs are at about ambient, even in traffic, unless I get hard on the boost and at the track, in ~95* my IATs are typically at 102-108* at the start of a run (after a good burnout) and typically max out at ~130-135 at the end of the 1/8 and by the time I park in the pits, the IATs are back down to ~105-110. My ATF temps run ~170-190* on the street and usually peak around 190* at the end of a run at the track. I’ve never experienced a cooling problem at the track either.
With that setup, I can drive in traffic in high 90 degree weather with no cooling issues.
The only time my car has overheated was the couple of times I threw a belt (my own fault, from messing around with different tensioners, belts, etc., chasing an imaginary “belt-slip problem”) and I had to limp home.
I’m pretty sure I’ve interacted with most folks on here who have PD blowers on their cars, and I haven’t heard of one who has a genuine overheating problem. We all want “better”, yes, but that doesn’t equate to a problem.
At the end of the day, it has pretty much been documented that the trick to keeping ECTs down in the C6 is to ensure that you’re moving sufficient air through radiator to cool the engine, and the typical thick, centri intercooler blocks more airflow than the skinny/flat H/X core that comes with the Edelbrock and Magnuson kits. Having a fully shrouded fan (like the 2005 model cooling fan) helps tremendously as well.
Please note that I’m not trying to start any controversy. I just thought I would share my experience and point out the obvious to anyone who wants to do a little research on the topic.
Old Jul 15, 2021 | 09:58 AM
ls1wolf's Avatar
ls1wolf
10000% agree with this as Sammy and I are at similar power levels.
Old Jul 15, 2021 | 11:32 AM
chuntington101's Avatar
chuntington101
@CI GS totally agree with what you put and this has been echoed by the ZR1 people as well (many of which move to the maggy HE)!
the Cordes cooler I posted below was just an option for the centri guys to have a solution akin to what the PD blower peeps have. I.e. one that only adds a thin and large surface area HE added to the cooling pack.
Old Jul 15, 2021 | 11:55 AM
NormWild's Avatar
NormWild
Your IATs are taken pre-blower on a PD, so to saying what your IATs are is not accurate. Buy the S/C system that makes you happy, everybody thinks their choice is the correct one. I have 60K miles on my centrifugal and never even thought of overheating once, stock fan, stock radiator. Considering 1st & 2nd are already useless on the street, never once did I think, "Man, I wish this boost came on sooner."
Oh, and if you are set on a PD, I would only really look at the Kong Performance units, but JMO.
Old Jul 16, 2021 | 12:41 AM
CI GS's Avatar
CI GS
What are you talking about the IAT being taken pre-blower? Both the Heartbeat and the Edelbrock have IAT sensors post-intercooler. On the Heartbeat, it sits about 3” above the intake port of the number 3 cylinder, so I don’t know you could get a more accurate read of the air temps in the blower. Mind you, if that sensor was just slightly lower on my car, it would get hit by a mixture of nitrous and E85 when I’m on the spray. I would bet a good chunk of money that I would be seeing some frosty IATs then, maybe even better than when you spray meth on the sensor in a centri setup.
BTW: The Kong Performance unit is only an option for replacing a stock LS9 blower, since it’s designed to use the ZR1/LS9 belt system, and GM has long discontinued the LS9 drive kit, and, as far as I know, no one else offers all the components you need to install the Kong blower on a LS3. So buying one of those would be a huge waste of money, unless you already have an LS9 drive system (A/C compressor, alternator, balancer and all the necessary LS9-specific bracketry lying around.
Old Jul 16, 2021 | 10:10 PM
JetstreamGS's Avatar
JetstreamGS
No right or wrong choice here. My Vette has an AA kit and it’s a riot. My CTS-V is also a blast to drive. Each blower is best suited to the application. The Vette is light and nimble so Centri linear power curve compliments it well. The V is a heavy pig and benefits from all the low end torque. Each car has no issues blowing the tires off.
Old Jul 24, 2021 | 11:07 PM
THE BLADE's Avatar
THE BLADE
I have a Kong 2650 on my LS3 Grand sport!
Old Jul 25, 2021 | 01:33 AM
JetstreamGS
More details please
Old Jul 26, 2021 | 09:46 AM
CI GS's Avatar
CI GS
What are you using as an accessory drive system? What intake and throttle body are you using?
Pictures would be great too.
I assume you’ve changed the hood as well?
Old Jul 26, 2021 | 12:01 PM
THE BLADE's Avatar
THE BLADE
Default Kong 2650
Everything is ls3 except belt tensioner, had problems with the custom American Racing Solutions tensioner, it was garbage. Katech TB and a fiberglass aftermarket hood.
Old Jul 26, 2021 | 12:16 PM
CI GS's Avatar
CI GS
Interesting. How did you get that to work, with the different belt spacing between the LS3 and LS9 and with the power steering reservoir and alternator bracket being in the way of the LS9 blower snout/throttle body? What width belt are you running on it? A picture would be worth a thousand words...
Old Jul 26, 2021 | 03:30 PM
  #33
THE BLADE's Avatar
THE BLADE
Working on a picture!
Old Jul 27, 2021 | 01:38 PM
  #34
CI GS's Avatar
CI GS
Old Jul 28, 2021 | 09:46 AM
  #35
THE BLADE's Avatar
THE BLADE
Default Kong 2650
Old Jul 28, 2021 | 10:18 AM
  #36
CI GS's Avatar
CI GS
That looks awesome.
Nice to see that someone figured out how to install a 2650 on a C6.
Is that a 8-rib belt? You running a custom pulley on the blower, or just running the narrower belt on the 11-rib?
What kind of power/boost are you making with that?
Old Jul 28, 2021 | 02:17 PM
  #37
bigron1212's Avatar
bigron1212
That looks awesome.
Does this potentially mean one could also run the LS9 blower utilizing the LS3 drive system with the custom pulley he is using?
To Another P/D vs Centrifugal Thread
Old Jul 28, 2021 | 02:38 PM
  #38
m60gov20's Avatar
m60gov20
x2!
Old Jul 28, 2021 | 02:56 PM
  #39
THE BLADE's Avatar
THE BLADE
System is 8 rib, Grip tech upper, Very mild setup!
Old Jul 28, 2021 | 05:46 PM
  #40
JetstreamGS
Sbe LS3? What power does it make?
