C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Is a boost a pump safe?
Old Aug 4, 2022 | 06:09 PM
HadEnough's Avatar
HadEnough
Banned Scam/Spammer
Default Is a boost a pump safe?
I want to get an A&A kit...then I read up on the Kenne-Bell boost-a-pump and have concerns about the spiked voltage burning out the fuel pump? I could just go with a better fuel pump, but that adds a lot to the cost.
Anyone have issues with the KB BAP? I'm worried about burning up the stock fuel pump...at the wrong time that could be disastrous!
Old Aug 4, 2022 | 06:56 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
My BAP has been working fine for the 4 years it has been installed, and my AFR during WOT stays right at 11.8-1 all the way to my 6,400 rpm shift point.
I doubt that it will burn-up your stock fuel pump since it only activates during a preset amount of boost pressure . (and for how long is the normal driver going to be in boost .. not for long periods of time).
I am using a 4 PSI Hobbs switch to control mine ... only increases fuel pump voltage when operating above 4 PSI boost.
Attachment 48332496
Old Aug 4, 2022 | 07:13 PM
Turbo6TA's Avatar
Turbo6TA
Maximum LS3 Fuel Pump Flow with Installed Boost-A-Pump
Increases Pump Voltage . . .From: 13.5 Volts .. To: .. 17.5 Volts . .(Only When Above 4 PSI Boost)
. . . - Resulting In -
Increased Pump Flow . . . . .From: 225 L/Hr .. . To: .. 325 L/Hr
Old Aug 4, 2022 | 08:24 PM
SteveJewels's Avatar
SteveJewels
The one on my car ran for 8 years.
The only reason I took it off was I converted to E85 in the spring and needed more pump.
Old Aug 5, 2022 | 08:27 AM
Spaceme1117's Avatar
Spaceme1117
Same here. Been running a BAP with my E-force with a 3-PSI Hobbe switch no problems for over 3 years.
I would recommend getting a Racetronix Fuel Pump Wiring Harness: C56 Fuel Pump Wiring Harness
It is plug and play and will upgrade the wiring in your car so that there will be no voltage drop to the fuel pump. Most C6's drop 1 or 2 volts with the stock wiring. Racetronix also has an add on connector specifically for BAP's that make it Plug and Play with their upgraded fuel pump wiring. Honestly, this is an excellent upgrade for any C5 or C6.
Old Aug 5, 2022 | 01:29 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
The KB BAPs have been very reliable and we've been running them for years on the vettes. Only time I see issues is when someone does a poor job wiring causing loose connections which increase amp draw. Or when someone deletes the Hobbs switch and tries to run it at 17 volts full-time, that will burn up a stock pump over time. If you install it properly it will work as needed.
Old Aug 11, 2022 | 12:45 PM
streetking408ys's Avatar
streetking408ys
I've run several on different projects for several years on each. Zero issues.
To Is a boost a pump safe?
