C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
MSD Intake with YSI
Old Oct 30, 2022 | 04:28 PM
Prostreet513's Avatar
Prostreet513
Default MSD Intake with YSI
I just purchased a YSI kit and wanted to ask about intakes. I’m currently running an MSD but wanted to know if anyone had good luck with those on boost or if I should look into another intake.
Old Nov 5, 2022 | 11:40 PM
c5mtl's Avatar
c5mtl
Sell it for a decent amount and go back to stock.
Old Nov 23, 2022 | 10:37 PM
gnx7's Avatar
gnx7
I run a stock LS3 intake manifold with MAST heads making 1200rwhp shifting above 7000rpm with 88mm turbo and LS9 bottom end. It makes more power than I can use. 22psi max. makes 1060rwhp on 14psi.
That being said the MSD intake works for Feras and his twin turbo C6. I have HEARD of FAST intakes having issues.... but not as much for the MSD.
https://www.holley.com/blog/post/fer...k_competition/
Old Nov 24, 2022 | 01:25 PM
lt1z's Avatar
lt1z
If running LS3 style heads and not spinning 7500+ stock LS3 intake FTW.
Old Nov 25, 2022 | 10:47 AM
gsx1300rrr's Avatar
gsx1300rrr
LS2 or LS3? If I'm not mistaken they never made the MSD for LS3 because they couldn't get a design that flows better then stock. I have an MSD atomic airforce on my LS2 pushing 21psi on a billet wheel YSi and it's been great! About to switch up the heads and go LS3 though and will probably run a stock LS3 intake.
Old Jan 16, 2023 | 10:32 AM
gsx1300rrr's Avatar
gsx1300rrr
I'd like to retract my previous statement, haha. Doing upgraded LS3 heads right now and pulled the MSD Atomic Airforce off, it turns out it did NOT like the boost very much.
Old Jan 16, 2023 | 05:02 PM
PSSSSSHC6's Avatar
PSSSSSHC6
Look at RAPID 3D on facebook.
Old Jan 31, 2023 | 10:14 AM
Prostreet513
I ended up getting a BTR intake. I know I may loose some on the low end but I will be spinning over 7000 so I decided to go with it.
Old Jan 31, 2023 | 10:17 AM
Prostreet513
Hopefully you only have to replace the runners so you can fix it and sell it.
To MSD Intake with YSI
