C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
SmoothBoost Electronic Boost Control
Old Nov 30, 2022 | 12:34 PM
C6_Prodigy's Avatar
C6_Prodigy
Default SmoothBoost Electronic Boost Control
I recently stumbled upon this product and wondered if anyone here was running it or knew someone who was.
https://www.smoothboost.com/p-41-centrifugal-supercharger-boost-control-kit-by-smoothboost.aspx
It's an electronic BOV to precisely control boost levels.
In theory, you could pulley down a bigger centri to get it spinning quicker for more power at the low end but prevent it from providing too much boost on the top end. Too much trust in an electronic BOV or good solution?
What do you think?
Old Dec 1, 2022 | 03:02 PM
CDALS7's Avatar
CDALS7
I know people have toyed around with wastegates on blower setups to accomplish the same thing. I thought the problem is over spinning the head unit on a centri systems when trying to limit boost like this. I have a procharged fbody so I would love something like this just not at the expense of damaging the blower. Not sure about PD blowers and a system like this.
Old Dec 2, 2022 | 07:59 AM
El_Steveo's Avatar
El_Steveo
When I had my GMC Sierra with a Whipple, plenty of guys were using smooth boost and loved it. It's an expensive system but worked very well.
Old Dec 2, 2022 | 01:00 PM
SteveJewels's Avatar
SteveJewels
I am working on something less sophisticated. I have a manual boost controller connected to the BoV, set to limit CSC boost to 9.5 PSI which gives me 750 WHP. Part 2 is a boost solenoid controlled with a switch. It will close and block the boost controller so boost will go to as high as the CSC will make.
I am working on a linear type controller for the solenoid to have an adjustable soft close, 2 seconds or so.
The system will work as a push to pass.
To SmoothBoost Electronic Boost Control
