C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Vortech v13
Old Oct 12, 2023 | 08:51 AM
  #41
jacked cobra's Avatar
jacked cobra
Originally Posted by Al_Scrap
How much is this unit? $
about 6k
Old Oct 12, 2023 | 02:06 PM
  #42
Sncobra331's Avatar
Sncobra331
Originally Posted by jacked cobra
bov was leaking to weak a spring. Yes leaking at the the track
that's impressive to pick up 6 with it bleeding boost. Finally an upgrade to the ysi from them. Thanks for posting the info, very helpful 👍
Old Nov 28, 2023 | 11:24 PM
  #43
jacked cobra
Fixed boost leak made 29 psi
Old Dec 30, 2023 | 08:17 PM
  #44
Dimewise's Avatar
Dimewise
Any more updates to this?
are you selling the YSI bc I’m interested in one
Old Dec 31, 2023 | 10:18 AM
  #45
jacked cobra
far as updates no problems with it makes a good amount more power no dyno numbers but boost on boost picked up 10mph in the 1/4 mile. And yes I’m selling the ysi send me your offer it has a v band flange welded onto it.
Old Dec 31, 2023 | 11:02 AM
  #46
Dimewise's Avatar
Dimewise
Pm sent
Old Dec 31, 2023 | 06:42 PM
  #47
jacked cobra
Pm sent
your mail box is full. I can send you video of staff play on ysi. There is none
Old Dec 31, 2023 | 07:03 PM
  #48
Dimewise's Avatar
Dimewise
try now pls made room
Old Dec 21, 2024 | 11:23 AM
  #49
gsx1300rrr's Avatar
gsx1300rrr
I see this post is about a year old, but I’m considering switching my like new YSI-b out for the V13, I currently have the same pulley combo (10 rib 2.7 upper & 8” lower) and it would be going on a LSR 427 with 11:1 CR on E85 (street car). Do you mind sharing your experience after having it for about a year? Belt life? Do you lose a noticeable amount of mid range you get with the YSI? Then also I’m curious if you were able to fit a filter, or do you just run w/out one? Thanks!
Old Dec 21, 2024 | 12:19 PM
  #50
jacked cobra
belt life is good after I got alignment right. No difference in mid range. I made my own intake pipe to the supercharger and can fit a filter. But I choose not to run one.
Old Jun 29, 2025 | 04:14 PM
  #51
Fredyp's Avatar
Fredyp
1st Gear
what pulley combo are you running on your v13?
Old Jun 30, 2025 | 08:49 AM
  #52
jacked cobra
2.7 blower 8in crank
