C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Tuning help for 6L80
Old Sep 12, 2023 | 06:54 AM
Icevettez06's Avatar
Icevettez06
Default Tuning help for 6L80
Hi. I did swap 6 speed to 6l80. I need recommendation on some one capable to tune the transmission. Car have fully build 429 ls7 ( RHS block) and APS /DKT 62/66 turbo so it make lot of power.
Old Sep 12, 2023 | 12:44 PM
Jason Zajac's Avatar
Jason Zajac
Would help to know a location. Engine & transmission tune are linked together so you will probably not find someone to just tune the transmission alone
Old Sep 12, 2023 | 03:46 PM
Icevettez06
I´m in Iceland. Car have ProEFI and I have HP Tuner for trans. Trans I put in the car is from 890 rwhp pro charger c6. Trans is so pose to hold + 900 rwhp. I have the HP tuner file from 6l80 and it have difrent tune than stock 6l80. I dont want to brake the trans LOL.
Old Sep 13, 2023 | 08:44 PM
thehulk's Avatar
thehulk
Check your DM
Old Sep 13, 2023 | 10:21 PM
TurboLX's Avatar
TurboLX
If your ECU does not output a reasonably accurate engine torque number to the TCM, you are going to have a VERY difficult time getting it to control the transmission properly. 6l80 is a torque-based clutch to clutch transmission.
I always instruct clients that the first step in proper modern transmission tuning is to get the engine calibration correct. This includes air per cylinder, which feeds the torque model that is relayed to the TCM.
Old Jan 5, 2024 | 06:51 PM
Rkreigh's Avatar
Rkreigh
isn't Circle trans shop doing well with these now? Like 9 and 8 sec performance?
Very curious about high hp builds for this box
Old Jan 8, 2024 | 06:03 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
I've sent several guys to speak with this trans tuning guru.
http://6l80etuning.com/
Old Jan 9, 2024 | 09:44 AM
da6speed's Avatar
da6speed
Check with Asylum Motorsports in Baton Rouge, Louisiana. Justin is very knowledgeable with ProEfi (does a lot of them) and he also builds and tunes 6L80s. He tuned my car, which is also TT/6L80 build with ProEfi. Before I went TT/ProEfi, I ran the stock ecm with Procharger and made 800+rwhp for years and I'm still on the stock trans.
To Tuning help for 6L80
