C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Need build help
Old Sep 18, 2023 | 06:11 PM
LSTX's Avatar
LSTX
Default Need build help
I have been reading and watching videos for the past few months to figure out my build. The more I know the less I know. Hoping I can get some experienced input/advice. I don’t have deep pockets but believe in the “buy once cry once”. And yes I know going fast isn’t cheap but trying to be smart/budget minded where it matters. I would like the ability to increase power later on without pulling the engine. I currently have an engine block and the car. Looking to do all the work except long block assembly. If I could pay a shop to provide a build “list” that would work too.
Use: Be able to drive/cruise without worry. Occasional roll race in Mexico. Nice choppy cam. Will go FI due to hp goals.
Short term goal: 700-800 whp
Long term: 1000 whp potential
Car: 2007 Z06, everything is stock minus engine and no dry sump system
Engine: (purchased) Darton sleeved 427 LS3 from GS, most likely end up wet sump. Are 1/2 inch head studs needed?
Crank: Callie’s compstar? 4.00
Rods: Callie’s compstar?
Pistons: diamond? 4.125
Cam: Brian Tooley boost cam?
Lifters: LS7
Timing chain: C5R
Lower pulley/balancer: ATI?
Heads: LS3 or LS7 or LSA? Aftermaket?
Intake: LS3 or LS7 oem?
Throttle body: stock size
Catch can: ?
Exhaust: 2 inch with 3 inch x pipe dumped
Compression: 10:1 or 10.5:1 ?
Fuel: leaning towards E85
Fuel system: fore dual or triple? Open to other more affordable options? Rails? Injectors?
Power adder: AA kit Ti. Would prefer PD supercharger but not an option at whp goal
Radiator: Dewitt shortened
Fans: Electric? Live in hot and dry TX
Clutch: Monster
Drivetrain: upgrade as needed
To accomplish 1000 whp later on could I change to better heads, bigger throttle body, intake, YSI, and larger injectors?
Appreciate your time/input.
Old Sep 18, 2023 | 06:56 PM
Al_Scrap's Avatar
Al_Scrap
Johnson 2110 lifter
10.5 compression ratio
E85
Triple fore
Full lenght radiator stock or dewitt, modify your radiator cradle
Mighty Mouse catch can
Stock TB and intake are fine for 1000whp
......Andddd that my 427 post lol
Old Sep 21, 2023 | 01:30 PM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
I'd use ARP 234-4317's but you could get away with 234-3610's.
Rotating assembly and BTR cam is fine.
LS7 lifters haven't done well for us in recent years, I would go with Johnson 2110R's.
LS3 or Frankenstein M311 w/ stock LS3 Manfold and TB
ID1300X & Dual Pump Fore will take you all the way to the 1000whp goal.
Tilton ST246 w/ Solid Cerametallic Hub
E85 & 10.5
Venting the hood helps a lot for the summer temps.
Old Sep 21, 2023 | 07:17 PM
LSTX's Avatar
LSTX
Thank you, will look into those lifters. Glad to catch this now. Any reason to stay with dry sump system if I’m not road racing?
Old Sep 21, 2023 | 07:35 PM
Closed at OP request.
Edit: OP has followed up and requested that the thread be re-opened as he is getting responses. Opened the thread again.
Old Sep 22, 2023 | 09:14 AM
Dane@LGmotorsports
Unless it's significantly less expensive to go wet sump I would stick with dry sump. Better oiling is better for longevity in any application.
To Need build help
