C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
P0606 DTC problem
Old Oct 26, 2009 | 07:39 PM
GETUSUMM's Avatar
GETUSUMM
Default P0606 DTC problem
I have searched around for others with the same problem but cannot find the correct answer. What is the cause of this code? My car is a 2006. The car only trips the code when I do a good burnout and I am about to stage at the track. I hurry up and clear it but sometimes it comes it comes back when I launch. This sucks. I have reset battery, reset code etc etc.
Old Oct 27, 2009 | 08:20 AM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
"P0606 PCM Processor Fault"
http://www.gearchatter.com/viewpost14066.php
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Dec 21, 2009 | 09:55 AM
GETUSUMM's Avatar
GETUSUMM
We reflashed the computer with HP tuners with latest build and problem was fixed. Thanks
Old Dec 21, 2009 | 11:04 AM
foff667's Avatar
0foff667
Former Vendor
I know with LS1's this problem usually doesn't just go away, it means theres an issue with the pcm, good luck if it keeps holding out on you though.
Old Jan 2, 2010 | 04:35 AM
VIGASH's Avatar
VIGASH
3rd Gear
yeah i have to say thanks as well. even though i got bad news with a good tune it was still well worth the money to come up there and get clark to check out my car. clark and shawn, i'll be doing the leakdown test on tues or weds and i'll let both of you guys know what went down. thanks again for all the help!
To P0606 DTC problem
