C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Help. Massive PCM Problems
Old Nov 3, 2012 | 07:30 PM
BadgeZ28's Avatar
BadgeZ28
Default Help. Massive PCM Problems
I had a rattle in the dash in the gauge cluster area. I took the hot cable off he battery and proceeded to disassemble the bezel and instrument cluster. Reassembled everything and hooked the hot back on the battery. Now I am getting a SES message on the DIC along with low fuel and service anti lock brakes. These messages keep cycling. When I shut the car off, the yellow light on the start button flashes until I press it off again. I can't put the car in gear (auto). What the hell did I nuke? Thanks
Old Nov 4, 2012 | 06:04 PM
BadgeZ28's Avatar
BadgeZ28
Found the problem. I damaged one wire. Repaired and heatshrink added. Amazing what on bad wire can do
Old Nov 4, 2012 | 10:03 PM
j_digi454's Avatar
j_digi454
Stuff like that is maddening. I think we've all had a similar issue one time or another. Glad you found it.
To Help. Massive PCM Problems
