C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Intermittent Starting Problems HELP
Old May 23, 2013 | 11:57 AM
CalifTom's Avatar
CalifTom
Default Intermittent Starting Problems HELP
2008 Coupe. Approximately every 10 days the car will not start. All the LED's come on and I can hear clicking. Westloh determined the battery is OK and confirmed the grounding is secure. They cannot duplicate the problem after having it in for one week. HELP!!!!!
Old May 24, 2013 | 07:55 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
If you have long tube headers wrapping around the starter, the starter is starting to go.
I had the same thing and had PowerTech performance change out the starter and I havent had the issue since.
Old May 24, 2013 | 01:41 PM
JRHAWK9's Avatar
JRHAWK9
I had this issue on my '08 and from previous similar experiences I swapped out one of the relays under the hood and it's been fine now for years. If the car is not turning over (starter is not engaging) when the start button is pressed, this would be the first thing I would try. I believe it's the starter relay, if I remember correctly.
Old May 28, 2013 | 12:04 PM
CalifTom's Avatar
CalifTom
Default 2008 Fixed
It was the solenoid inside the starter. The local Chev Dealer couldn't recreate the problem until they parked it out front for me to pick-up unfixed. Lo and behold, it didn't start! Apparently the starter's proximity to the exhaust manifold cooks the solenoid. As mentioned above, the problem was intermittent although it was getting progressively worse. Thanks for your help.
To Intermittent Starting Problems HELP
