A totally honest review about Chuck @ C.O.W. and his tune
I had Chuck at C.O.W. sell me one of his mail order tunes with his booster he brags about to see if it's true or not . I also seen a few reviews that his customer service had problems, well here it is. I received the tune tune had a few questions and called I was helped by someone or Chuck. I ran into a problem and needed help I called again and Chuck went far and above to help me till it was right and told me ( take it for a drive and call me back) I did and now the car don't push you into the seat it Throws you into the back of the seat hard !!!!. His tune is right on the mark and so is his customer service, I would use him again and send anyone to him. Great tune & customer service and worth every penny I spent with him. Thank you very much to the team at C.O.W.
I agree with you 100% , The guy cares about giving you what you want and will keep working with you till your happy because that's what he did for me. I could not be happier
I have called him a couple of times. I haven't made the move on what I am going to do with the car yet, but I know he is going to be the one doing it. I am lucky enough to be about 15 minutes away. I ave called and talked to him, and met one of the guys that works with him, nothing but good things to say from me!!!!
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Hey Mr.Taco....
Hey Mr.Taco.... What kinda car do you have? C6 I presume?
Chuck CoW
Unfortunately I had a different experience with Chuck. He did a tune and a CowBoost on my 07'Z06. A couple of days later, I noticed the car was running 15 degrees hotter than normal. Called him numerous times to get some piece of mind about the situation. He literally didn't respond to me for a year! The cowboost ended up being too sensitive and I had a local tuner (Dave at Precision Dyno), dial it back. I won't be using Mr. Cow for any of my tuning needs in the future and share my experiences with my local Vette friends.
As for how you say you were treated, that has never been my experience with Chuck over the many years I and numerous people I know have been his customers. I have personally recommended Chuck and the CowBoost to friends of mine with Vettes, CTS's and Camaros and they all are thrilled and cannot be happier with Chucks service
Looking forward to what Chuck and his team come up with for the C7
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Turbooo2u
Besides blaming a tuner for your temperature issue,, what have YOU done to help improve the increase in temp?????
Clean the radiator?
Check the thermostat?
Make sure the FAN is running correctly??
Has the outside temp and humidity changed (HIGHER)??
Other than making your fan turn on sooner and run longer, Thats about all that the tune can do to lower the temps. Problems on the C6s is, If you turn the run frequency up too far on the fan, ypu will COOK the fan connector.
Chuck tuned my 06 and 11 Grand Sport and I couldn't have been happier!
As long as your not outright belligerent about how you approach your issue, Chuck has always been responsive to me or anyone that I have recommended to him.
Bill
Clean the radiator?
Bill
IMMEDIATELY after the tune, I noticed the car running noticeably hotter. All I wanted was some input and reassurance. I didn't get it.
So I won't be using Chuck again. I found a tuner close-by who does excellent work ( Dave, owner of Precision Dyno) who fixed my problems and improved on Chuck's tune without almost getting me killed!
Turbooo2u
Clean the radiator?
Bill
Clean the radiator?
Bill
As anyone with a C6 (or C5 for that matter) knows, these babies run hot at times....my question is was there a temp issue at all? And the other question is a whole year??? The more I think about it...so out of character for Chuck...IDK....
Improve on Chucks tune...haven't seen it yet...especially on GM high perf cars...the sheer number Chuck works on and sees in his shop as well as all the mail order tune business he does make his experience second to none in this business from what I have seen...
When did you get the tune and when did you experience it running hotter...dead of winter...summer? And what was the temp outside?
CoW Tune
I got Chuck to tune my 2010 GS less than a year after I bought it. He worked with me and fine tuned everything. No complaints and what a difference. I am fixing to send him my PCM to do his CoW Booster.
He is in the process of tuning my 2013 Chevy Silverado. He put the booster in the PCM and he is now putting his finishing touches on the tune itself. Man what a difference over stock! Even adjusted my speedo to compensate for 35" tires.
The booster in my Silverado is what convinced me I wanted the CoW booster on my Vette. It is unreal.
AAA+++ for Chuck. He is great to work with and very patient to ensure
everything is right.
Thanks Chuck,
Billy
Thanks Chuck,
Billy
Hi all have 2010 camaro with a custom supercharger set up,chuck built the entire tune including the cow booster trans tune and the car runs perfect and the performance numbers are off the chart,the guy is amazing at what he does,thanks marc
In reference to the comments from turboo2u ,i am running 9lbs boost, headers liquid intercoolerwith a vortec unit and my car runs at or below normal eng temp after chuck did the tune,car is driven daily and sits in traffic,never runs hot
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A DYNO TUNE is for bragging rights. A true professional on the road tune, (Where you drive your car every day) is more realistic.
