metal/metal rubbing noise only while moving
Hey guys,
I just noticed a very quiet metal on metal rubbing noise ONLY when its moving. I suspect this rules out anything on the clutch end (pilot bearing, slave, flywheel, etc.).
I initially thought it was the torque tube - which it still might be - but its very QUIET. I wonder if its the TT going out?
2nd, I thought perhaps it was my diff - However I don't know how to test it, I lifted the car off the ground and drove it in 1st - no noise but a lot of unhappy shuddering from the diff - but i suspect thats due to unloading/loading of the diff gears because theres no load on it.
3rd, I thought it might be a wheel bearing. However, I lifted the car and spun the tires and it doesnt make any noises. Of course this doesnt mean its totally fine, perhaps its just starting to go bad so I cant spin it fast enough to make noises?
lastly, I thought MAYBE its the brakes. There is a pronounced ridge on the outer edge of rotors which may be contacting the brake pads when im driving...
it is not a constant "rolling" noise (i.e. marbles in a can - torque tube issue). it sounds ALMOST like a brake pad that is vibrating, but its a little to consistent at speeds and very quiet (? possible?). I will pull the tires off this weekend and double check this... I am heavily leaning towards brakes (hoping, actually).
There is some play in the diff.
There is a oil wet spot between the transaxle and torque tube (???)
Should i start looking for TT bearings? A new diff?
Thanks!
Thanks!
St. Jude Donor '11, '14
I would start by finding what the leak is. That should point you in the right direction hopefully. They could be unrelated though
If you can rock a wheel it might be a bearing.
If it is brakes dragging the speed of the sound should change.
I would do the brakes if needed. Check the wheel bearings by in and out movement. Find the leak and fix. Just go through the systems repair/fix as needed.
Good luck
Good luck
