C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Octane Booster
Old Apr 30, 2017 | 04:13 PM
John McMartin's Avatar
John McMartin
1st Gear
Default Octane Booster
1995
Can I put an Octane booster additive to the fuel? what brand is recommended?
We filled the tank with regular unleaded ..... half tank , so now we are getting engine ping & hesitation.
or should it be drained.... this don't look like easy access thou.
suggestions ?
John
Old Apr 30, 2017 | 07:14 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
You could try to add some but I don't think it will help much. Maybe run your car fairly easy and burn some of that gas out then re-add Premium.
Old May 1, 2017 | 09:44 AM
Unreal's Avatar
Unreal
What Todd said, drive easy until it is out, then just refill with premium.
If that isnt possible, torco or boostane work great. About $25 off amazon.
Old May 1, 2017 | 07:31 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If you really want it out, remove the valve in the schrader valve on the fuel rail, stick a fuel hose on it and jumper the fuel pump relay on. Fuel wil pump out pretty quick. Though to be fair it will only drain one tank, no fuel pressure = no fuel transfer system workie. Better than nothing I guess.
Old May 6, 2017 | 12:59 AM
User Omega's Avatar
User Omega
What mods does this car have? There is no reason it should run too poorly unless you are flooring it around.
Old May 7, 2017 | 06:20 PM
Midnight08's Avatar
Midnight08
Plenty of suggestions on how to deal with current tank.
Most of the fuel additives are junk. From a pile of research I did on this, Torco is definitely a good product, though more expensive and capable than I was looking for. I settled on Lucas Octane Booster (LOB), as it will raise the octane of the gas a full 30 points, which translates to a boost of +3. A single bottle is good for up to 25 gallons, though I'm usually closer to half to a bit more than half of that at fuel fill-up. West of the Mississippi, 91 octane is the best we have at most stations, and some don't even have that. So, I figure 91 from a good station plus a bottle of LOB for each fill should get me to 93 reliably, which is what my car is tuned for. No issues since adding it - but plenty of power, from upgrades and tuning, not the bit of octane boost.
Note: I get LOB as a case of 12 bottles for $78 and I figure this will last me about a year, so a pretty low price to pay for a couple of extra octane levels. I'm using a CAI that gives me ambient to very near ambient AIT, LT headers, and some other odds and ends. Fun car to drive, soon to head to the dyno to see where I'm at, relative to before the additions.
To Octane Booster
