ABS timing out when bleeding brakes
I've tried an Autel and a Tech 2 scan tool to bleed the brakes. The procedure is ending after bleeding the right rear caliper and giving an error msg indicating the abs is timing out.
also, I had to have the engine running as in accessory mode I received an error indicating no comm with the abs module...that is the only one the tech 2 wasn't communicating with.
is there a way to connect to the canbus(?) without running the engine i.e. put the car in check engine mode without starting?
where do I start looking?
2008 C6 Base LE1 coupe with 96.5K miles
Dave
