C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
IAT sensor need help
Old Dec 20, 2019 | 05:48 PM
bada's Avatar
bada
Default IAT sensor need help
I am changing to a Carb style intake. On my 1932 ford truck. But keeping my stock E38 EMC. And going to get a SD tune. I will be running a carburetor style, 14 inch round air filter. But I still need to install a IAT sensor. So where do I put it? And On my LS7 set up, the IAT and MAF are together in one plugin. So does someone make a IAT that, can be installed in the round air cleaner? And maybe plug into, the factory harness plug in? with the MAF wires removed. That would be ideal.
Any help would be greatly appreciated.
Old Dec 21, 2019 | 07:59 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There are 2 common sensors that can be used for "remote" IAT's:
There's a metal sensor which I believe is used on ZR1 and CTS-V's, you can see some pics at the link below. The part number is "WT382" and you can usually get them at Advance or Amazon, etc. has them easy enough. They tend to heat soak more so I'm not a huge fan of these anymore.
https://www.corvetteforum.com/forums...post1589497269
The better option for you is probably the GTO sensor and a grommet from Dorman, this style:
https://www.corvetteforum.com/forums...post1594496212
IAT sensor is from a 2004 GTO, part number WT3036P
The rubber grommet is Dorman part number 42330
The IAT pigtail is part number PT778
Advance Auto has all of these in stock usually so that makes it easy
Old Dec 21, 2019 | 09:36 PM
aaronc7's Avatar
aaronc7
How does the rubber grommet setup work under boost?
I put my IAT sensor in the intercooler cold side end tank which more or less prevents heatsoak issues.
Old Dec 21, 2019 | 10:10 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Haven't had any issues with it. ECS uses the same one pretty often. You do need to be careful when drilling the hole to make sure the grommet fits as tight as possible, but I haven't had any issues with it leaking.
Old Dec 22, 2019 | 12:07 PM
bada's Avatar
bada
Thank you greatly for all the part #s. And this great information.
And this will work with, my E38 ECU , and a LS7 engine?
Old Dec 22, 2019 | 05:05 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i just finished putting up a thread in the tech section looking for the iat pinouts in the maf when i saw this thread.
https://www.corvetteforum.com/forums...r-pinouts.html
Old Dec 22, 2019 | 07:26 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, IAT is the wires that are the same color, should be the first two or the last two wires
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes
Old Dec 23, 2019 | 05:46 PM
bada's Avatar
bada
Yes
Thanks again. Great info.
Old Dec 23, 2019 | 05:49 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
no problem
To IAT sensor need help
