C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
code scanner selection
Old Sep 3, 2020 | 01:44 PM
aj15479's Avatar
aj15479
Default code scanner selection
I have decided to buy an OBD2 scanner or whatever I need to do the following: Check/reset engine codes and also check and evaluate body control codes, ie wheek speed sensors, airbag sensors and such things. I have a little icon of an airbag on my dash near the fuel gauge and I don't know what that means.
Old Sep 19, 2020 | 05:52 PM
Dcasole's Avatar
Dcasole
common problem , run the seat all the way back , disconnect battery , unplugthe yellow connectors under the seat , clean connections with electrical cleaner, plug back in making sure locking tab engages, then use a nylon tie wrapped around both the male and female connections , pull it tight so it keeps connection tight . Rinse and repeat on the passenger side . Light should go out, if not ..... you have airbag issues which I would have someone look at
Dave
