Various products install questions
Old Feb 3, 2005 | 04:04 PM
mbonanni1856's Avatar
mbonanni1856
Default Various products install questions
I just got back in town from a factory delivery of my dad's C6. I have a bunch of parts waiting to go on the car and I want to get any info that I can on installing these parts before I start. Here is what we have...
Corsa Exhaust
Color matched third brake light housing
Vortex intake
side air vent screens
and I think that is it.
Any info would be helpful. Thanks.
Old Feb 3, 2005 | 04:21 PM
Violet's Avatar
Violet
search and check the FAQ. i'm pretty sure how-to's for ALL those have been previously posted.
Old Feb 3, 2005 | 05:23 PM
mbonanni1856
OK Thanks
Old Feb 3, 2005 | 05:26 PM
mbonanni1856
Well it may just be me, but I cannot find any do it yourself or how to articles on this site.
Old Feb 3, 2005 | 05:34 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
DO not waste your time on the vortex intake !
Old Feb 3, 2005 | 06:57 PM
vetteb_96C's Avatar
vetteb_96C
Don't use the sticky tape method for the side vent screens, they will fall off. Most say epoxy works the best.
Old Feb 4, 2005 | 01:02 AM
c6nut's Avatar
c6nut
You mean the Vortex *** rammer I tried it and it sux. Returned it.
Old Feb 4, 2005 | 01:49 AM
shopdog's Avatar
shopdog
Corsa Exhaust
Vortex intake
Catback install is a simple matter of unbolting the stock system and bolting the replacement system in its place. It is self-evident what needs to be done once you're under the car. Don't expect any performance improvement, but it will be louder than stock.
To get to the bolts holding the third brake light, remove one of the inboard tail lights (one torx screw accessable from the rear), and reach through the hole to get to the bolts. Don't forget to unplug the wire to the brake light before removing it. Don't overtorque the bolts when installing the new piece, and don't forget to plug the wire back in before you reinstall the tail light.
The best install advice on the Vortex is *don't*.
The dress up screens for the fake side vents can be installed by removing the access panel in the inner fenderwell, pop out the black plastic filler piece, and use double stick tape or glue to attach the screen. Reassemble in reverse order.
Old Feb 4, 2005 | 11:05 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I installed the Corsa myself. The instructions come with it. They are very good. I only had two problems. (1) Completely remove the H pipe, it makes taking it off a lot easier. (2) When removing the mufflers, it it easier to take the hanger brackets off the frame attached to the muffler brackets the trying to take the hangers out of the rubber hangers. Then before you install the Corsa mufflers, put the hanger brackets in the new muffler hangers. Put muffler pipe in over the axle pipe and raise muffler up and reinstall bolts into muffler bracket and frame. You will find this goes a lot eaiser than trying to take the hangers out of the rubber hangers.
To Various products install questions
