Jacks
Old Mar 3, 2005 | 11:50 AM
PJinNJ's Avatar
PJinNJ
Default Jacks
A quick question on jacks. I can't seem to locate one low enough to use with the pucks. Is there a brand most use? I did find a 3.75 low clearance one but the puck adds an inch and that's a 1/4 more than the clearance. Maybe I need to raise the car? Hope not.
Old Mar 3, 2005 | 12:00 PM
andreas g.'s Avatar
andreas g.
Default Check costco
Costco has an aluminum jack that fits under my C6 at the jacking points. It's like a nascar jack. $135.00. weighs 43 lbs.
Old Mar 3, 2005 | 12:15 PM
tom4416's Avatar
tom4416
Sears sells a 1-1/2 ton aluminum racing jack for $119.99 that works but Pep Boys has a flyer out this week with essentially the same jack (both made in China, go figure) for $69.99 - same profile. I've got the Sears and picked up the Pep Boys today so I can lift both sides. The Sears works with the pucks and I don't see why the Pep Boys won't also (I think their probably the same jack).
Old Mar 3, 2005 | 12:25 PM
PJinNJ's Avatar
PJinNJ
Default Great
Cool, I guess Alum is the key along with racing jack. Thanks a bunch.b
Old Mar 3, 2005 | 08:14 PM
cielosf's Avatar
cielosf
Default Jacks
Today I bought two aluminum racing jacks for $140.00 at Pep Boy's! They must have been assembled by 10 year olds. Talk about cheap labor
Old Mar 3, 2005 | 08:17 PM
CaptainMike's Avatar
CaptainMike
Thanks Bro......picked up my 69.99 jack today.....
Old Mar 6, 2005 | 09:56 PM
Geoff17's Avatar
Geoff17
Do you have lift pads for the C6? I have not been able to find any?
Old Mar 6, 2005 | 10:21 PM
shopdog's Avatar
shopdog
Harbor Freight sells one branded "US General" (Harbor Freight brand for a Chinese jack). Sears, Pep Boys, etc also sell the same thing under their own brand names. Prices vary between $69 and $130, same jack, so shop around. Works fine.
Old Mar 7, 2005 | 11:47 AM
LS1LT1's Avatar
LS1LT1
Yes, the Harbor Freight jack appears to be the exact same one as the new Pep Boys (similar pricing as well) version, very light jacks too.
Old Mar 8, 2005 | 04:13 PM
corvette1's Avatar
corvette1
I've been looking for a low profile jack as well and came across this comparison information, for what it's worth:
http://mymiata.paladinmicro.com/MiataCRALJack.htm
Old Mar 9, 2005 | 12:44 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Harbor Freight Aluminum Racing Jack - 79.99
3 inch saddle height
3000 LB capacity
Saddle is a rubber pad that rotates 360 degrees
Made out of Aircraft aluminum billet material...
ITEM 91039-2VGA
Old Mar 9, 2005 | 02:06 AM
shopdog's Avatar
shopdog
Cliff apparently wasn't aware that HF also sells the heavier duty jack, normally for between $159 and $179 depending on which sale flyer you get. So if you want to buy the heavier duty jack from them, you can.
I bought the smaller jack, and at least mine seems very well made. The knurling is sharp, the fit of the parts is good, the anodizing is good, etc. When I took mine out of the box, it would barely lift, and only at the end of the stroke. A quick look at the instructions and I noted that the air bleed valve was open. I bled the jack as per instructions, closed the (nicely knurled) air bleed, and the jack works just fine.
Old Mar 9, 2005 | 10:05 AM
corvette1's Avatar
corvette1
[QUOTE=shopdog]Cliff apparently wasn't aware that HF also sells the heavier duty jack"
Good point. It appears he's not comparing apples to apples, more the light duty Harbor versus the heavy duty Sears. Thank you for the info on your jack, it helps with my decision.
To Jacks
