Callaway Products
Old Mar 5, 2005 | 03:12 AM
Hampi's Avatar
Hampi
Default Callaway Products
Hi
Since my dealer works together with callaway, I might use their aftermarket products. Afterall, their reputation seems to be very good.
Does any of you already uses their products like exhaust, headers or the honker?
Regards Hampi
Old Mar 5, 2005 | 07:56 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Originally Posted by Hampi
Hi
Regards Hampi
Which dealer are you using?? and where are they located??
I have driven a C6 equipped with the Callaway "Power Groups", as they are called.
I also own two Callaway Corvettes - both are extremely high quality and powerful These cars do exactly what they are said to do, every time they are called upon
The Honker can flow as much as 1500 cfm, or 32% more than stock - it is a VERY high quality piece
The C6 Honker is somewhat similar to the Callaway C5 Honker they offer only the C6 allowed a bit more flexability in the design, due to more room in the shroud area - An interesting note on the C5 Honker - the Mass Air sensor was moved right in front of the throttle body with that component - something GM obviously took note of and adopted for use on the C6
Combined with the Callaway Cat Back exhaust and Callaway headers (they leave the catalytic convertors in the stock location for emissions compliance ) the car picked up an extra 51 hp and 25 lb-ft of torque making the C6 even more driveable across the power band.
Those components have been validated and they are offered under Power Groups 1 and 2 with Power Group 3 soon to be validated - P.G. 3 includes Heads and Cam as part of the package.
I hope this helps - you are indeed correct, Callaway Cars has a long standing reputation as a top shelf Engineering Company and they design and construct their parts with impeccable fit & finish -
Old Mar 5, 2005 | 10:52 AM
Alex Levy's Avatar
Alex Levy
I assume your C6 51/25 numbers are at the crank because there is no way that you can get 85+hp at the crank from an Intake and exhaust as the C6 is an excellent breather direct from BG.
Old Mar 5, 2005 | 11:47 AM
FLC6's Avatar
FLC6
IS the honker a ram air effect like the Vortex? Is the shroud cut?
Old Mar 5, 2005 | 12:54 PM
Hampi's Avatar
Hampi
Thank you for your reply, its highly appreciated
I am living in Switzerland and my dealer is http://www.corvettetotal.ch/.
I will get my car in two weeks from him, by that date he might have some products from Callaway available.
Emission is a very critical point where I live so its very ok they leave the cats stock.
Looking forward to using these hot products. 50 PS is quiet a lot
Regards Hampi
Old Mar 5, 2005 | 04:36 PM
*89x2*'s Avatar
*89x2*
I am not quite sure what you mean like a vortex however, the Callaway Honker gets its air from the area under the shroud - like a "bottom breather" as what you see in the under hood compartment is totally sealed...
Old Mar 6, 2005 | 03:06 PM
Hampi's Avatar
Hampi
http://www.callawaycars.com/callaway...6_Products.htm
...well, I am not impressed with the figures...
Regards Hampi
Old Mar 6, 2005 | 04:18 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
i agree
Id rather do the stage 1 at ligenfelter!
Old Mar 6, 2005 | 04:29 PM
Hampi's Avatar
Hampi
Originally Posted by burtonbl103
i agree
you mean the 500 Bhp Kit?
Old Mar 6, 2005 | 04:49 PM
*89x2*'s Avatar
*89x2*
i agree
I am not saying anything against that company however, do you the facts to show that component for component, someone is making more (emissions compliant) power?
Just wondering
BTW, it is Lingenfelter...
Old Mar 6, 2005 | 04:54 PM
burtonbl103
Lingenfilter is doing it with factory cats and headders !
Old Mar 6, 2005 | 04:58 PM
jschindler's Avatar
jschindler
If either of them are using the stock cats, I assume the headers must be "shorties". Is this correct? The C5's generally didn't pick up hardly any HP with shorties. I'd like to know more about these (I assume that they are not relocating the stock cats???)
Any input on these questions is appreciated.
Old Mar 6, 2005 | 07:55 PM
FLC6's Avatar
FLC6
89x2,
Breathless Performance sells a Ram Air kit called the Vortex. I am surprised you never heard of it.
When installing the kit, you have to cut the shroud below where the stock air box sits.
This opens up a nice hole for air to come in.
Is that what the Honker does as well? Anyone?
Old Mar 6, 2005 | 09:00 PM
*89x2*'s Avatar
*89x2*
89x2,
Gotcha - I did not know you were directly refering to the Breathless kit when you said Vortex...
To what degree if any cutting needs to be done on the Honker I am not certain - I do not want to say one thing and it be another
It does draw the air from beneath however - very high quality piece
Old Mar 7, 2005 | 11:55 AM
LS1LT1's Avatar
LS1LT1
According to the site those numbers (or similar) were actually achieved with the Honker, headers, cat back PLUS the following:
CNC-Ported Cylinder Heads
Hydraulic Roller Camshaft
High-Ratio Rocker Arms
Chrome Moly Pushrods
Premium Seals & Gaskets
Or am I reading this wrong?
Old Mar 7, 2005 | 12:14 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Hampi,
Do you know Heinz Roth? He is a very smart Corvette guy that lives in Switzerland. If you need is information, let me know.
Randy
Old Mar 7, 2005 | 03:56 PM
Hampi's Avatar
Hampi
@Randy
I gave him a call about two weeks ago. Unfortunately he has no tuning yet for the C6, but he is working on it. There will be quite a run on the C6 so he better is
Old Mar 8, 2005 | 11:42 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Heinz works closely with us! He will have the stuff to tune about a day after us. We are waiting for all the bugs to get worked out.
Randy
Old Mar 8, 2005 | 12:03 PM
Hampi's Avatar
Hampi
sounds great
Unlike the States, in Europe most aftermarket exhaust and headers will be illegal or would cost a fortune to make them legal and the feds or quite picky on this one. Would be cool if there also would be a kit, where you do not have to change the stock exhaust system (like Lingenfelder)
To Callaway Products
