Base Line Dyno HP?
two correction factors in common use to standardize
dyno results. One is known as STP or Standard Temp
and Pressure and this correction corrects to 60
degrees. The other common correction standard
corrects to 77 degrees and a slightly different air
pressure.
According to Hot Rod, STP correction produces results
about 5% higher. In a recent test, they had an LS2 on
an engine dyno and it produced 400hp and 422 hp
correcting to both standards, respectively. They assert
GM does not use STP correction to rate its engines
but that most dyno operators do use STP. That's
certainly one way to get better hp numbers - use a
different correction factor than the factory!
Pat
Also, the operator has to know how to set it up, and make sure the car is at proper operating temperature (both coolant and oil). I would not get hung up on the numbers. This is also why I only dyno mine on "dyno days" where they dyno several other Corvettes. That way I am getting a meaningful comparison of how mine does compared to other like cars.
