Help ... How can you change the country code with the Tech 2 tool?
Old Apr 2, 2005 | 04:08 PM
rbl's Avatar
rbl
Default Help ... How can you change the country code with the Tech 2 tool?
Sending a car to Europe and I need to change the point of sale (country code) to EU. I finally fount the point of sale listed as USA in the navigation menus but I can not find a place in the BCM to send a new message to the unit to change it to Europe.
I need to do this so the Navigation unit will work correctly as well as the radio functions.
Naturally I tried this today while GM tech was closed!
Old Apr 2, 2005 | 11:20 PM
ZL-1's Avatar
ZL-1
If its like many other 05 gm cars, try this. Use the tech 2 and go to BCM setup. Click on "do you want to set up a new bcm?" Click yes. Then you may get a message "BCM is locked, can't reprogram" or something like that. hit "enter" and wait a few seconds. You should then get a message "do you want to set options?". The first page of options should be Country of Origin. Change as necessary. Finish by clicking "save options" on the following pages. Hope this works for you.
PS...as you probably know, the original disc in the nav only covers the US and Canada. While you have the tech 2 connected, go into "radio" also, and check your choice of countries there.
Old Apr 3, 2005 | 07:21 AM
6699's Avatar
6699
Just received my C6, imported from US, and as far as Navigation is concerned, the only thing I had to do was to buy the Europe DVD from a local dealer here in Sweden. It works perfectly.
Mikael
Old Apr 3, 2005 | 10:00 AM
rbl's Avatar
rbl
Thank you for the help ... I will try the BCM thing again.
To Help ... How can you change the country code with the Tech 2 tool?
