Change rear gears
Old Apr 3, 2005 | 04:26 PM
betweenvets's Avatar
betweenvets
Default Change rear gears
Can anyone tell me what the degree of difficulty and expense is in changing out the rearend gearset in the 2005 Corvette? I would like to go from the AT stock 2.73 to 3.42.
Thanks,
John
Old Apr 3, 2005 | 06:40 PM
crabman's Avatar
crabman
I have seen folks advertise gears with install for a low of 750 to a high of 950.
Old Apr 3, 2005 | 11:24 PM
boogieman's Avatar
boogieman
Default Go with the 390s if you will be drag racing
If you will be drag racing, I recommend the 390 gears. More bite! better launch! Price is around what the previous response mentioned.
Old Apr 4, 2005 | 04:43 PM
SHOOTER 49's Avatar
SHOOTER 49
I believe the cost to change from 2.73's is higher then qouted here. Thr reason being that the carrier or pumpkin is different. If you had the 3.15 it would be the 750-950 range as it would not require extra parts. I was qouted almost 2k by a speed shop to change out my 2.73's on my old ls1.
Old Apr 4, 2005 | 06:57 PM
crabman's Avatar
crabman
Your right, and sorry for posting incorrectly. Im going 3.90s myself and have been keeping a weather eye on prices but Im not facing the 2.73 problem and didnt think of it when I posted.
Old Apr 5, 2005 | 10:54 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We have the ability to upgrade any model of the C6 differential (2 or 3- series) for high performance use and have been building them for quite some time now. Many of the HD internal components, blueprinting techniques and HP metallurgical treatments we developed for the C5 unit will carry over to the C6 differential, so we have that area covered as well. Plus we've added a couple of new tricks for them here and there... Give us a call if you have any questions. (260)407-5455
Best Regards,
DTE
To Change rear gears
