Which rear end
Old Apr 3, 2005 | 04:58 PM
c5 devil's Avatar
c5 devil
Default Which rear end
I just bought a 2005 vette wanted to know how can i tell what rearend i have.....The dealer which i bought the car from does not know!!!!
Please help me.......
Also, over all what rear is better the 2.73 or the 3.15...........
Old Apr 3, 2005 | 05:01 PM
C6FirstVette's Avatar
C6FirstVette
Well lets start with this... do you have the Z51 with 6 MN or Auto?
No Z51 but have 6MN? or auto?
and
the rear ratio question...depends on what you want... higher number generally means faster acceleration but lower gas mileage...lower the number better cruising with lower rpms thus better mileage..so for drap strip junkies love the high 3 or even low 4 rear ends
Michael
Old Apr 3, 2005 | 05:44 PM
bj33813's Avatar
bj33813
If you have the automatic, you have the 2.73 unless you got the OPTIONAL ($395) 3.15 "performance " rear end.
Ck the window sticker.
Old Apr 4, 2005 | 04:30 PM
c5 devil's Avatar
c5 devil
Default Auto
Well my vette is an auto...i don't think i have the Z51 but i might...
You see i am living in doha, Qatar...and the dealership here know nothing about the vette's options.....
Well i undrstand that 3.90 gears would be better for take off..But if you think about it that way would the 2.73 be better for the long run..meanning would it give me more or extra mph....?????
Old Apr 4, 2005 | 05:23 PM
bj33813's Avatar
bj33813
you should be able to determine what the ratio is by counting as you carefully hit the throttle to turn the wheels with the *** end off the ground, and in gear I would think...lots luck tho.
With the 2.73 I would guess the top end might be a little more, your gas mileage should be better (not if you drive like the rest of us !)
Don't know about the Z51 tho as I don't have it...maybe someone else can pitch in here and tell us if there is a distinguishing feature he could look for ?
I do know that going from the 2.73 to the optional 3.15 gains you all of A TENTH OF A SECOND 0 TO 60, so it really is not that big a deal. Bragging rights mostly.
It seems to me I saw a post somewhere here that you can obtain (for $ no doubt), the original build sheet from the corvette museum, which would list everything on the bad boy you have. All you need is the VIN.
Good luck !
Old Apr 4, 2005 | 05:42 PM
Lowlead's Avatar
Lowlead
Look at the sticker attached to the inside of the glove box. If you see the code "G90" you have the 3.15 gears, if you don't see G90 you have 2.73.
Old Apr 5, 2005 | 02:38 AM
c5 devil's Avatar
c5 devil
Default :)
Thanx guys ..............
Old Apr 5, 2005 | 12:01 PM
bj33813's Avatar
bj33813
Thanx lowlead...I always wondered WHAT could fit in that glovebox...good to know.
To Which rear end
