Traction System Problem
Old Apr 11, 2005 | 03:14 PM
Burple_X's Avatar
Burple_X
Default Traction System Problem
On two occassions now, my car has thrown the Traction System Active message when I just rolling down the highway. Both time I was running just above 70mph. When the message comes on, the car slows to 70mph. I can manually turn off the traction control and all is fine again.
Last week I spent $800 for the dealer to replace the tire sensors in my aftermarket wheels. He was sure that was causing the problem . The car did the same thing this weekend with the proper (new) sensors in the wheels. So much for that theory!
Has anyone else experienced this? According to the GM dealer, it could be "any one of a hundred things" causing it. The car is about 2 months old now and has just over 2300 miles on it. The first time it did this was April 6. New sensors were put in on April 8. Then it did it again on April 10.
Old Apr 11, 2005 | 04:58 PM
SunsetVette's Avatar
SunsetVette
on my c6 my tracton control went bad it said service traction system though, and they really couldnt figure out what was wrong they switched a sensor somewhere and it didnt fix it when i start the car up and if its wet out and the tire break loose the traction control goes out and sais service traction system i even brought my car in to show them the light on so they didnt think i was crazy all i can say is im upset and youll have to just keep taking it back to them try and get your 800 dollars back too
Old Apr 11, 2005 | 05:07 PM
EHS's Avatar
EHS
Tire sizes please.
In other words, is there a greater than 10% difference between the circumference, front to back?
Old Apr 11, 2005 | 09:27 PM
Burple_X's Avatar
Burple_X
Default Tire sizes
Originally Posted by EHS
Tire sizes please.
275/35 ZR 18 Front
305/30 ZR 19 Rear
They have been on the car for over 2k miles and the traction system problem just started.
Old Apr 12, 2005 | 12:03 AM
haljensen's Avatar
haljensen
You have your Active Handling computer confused.
Stock front 25.72" dia. to your front of 25.58" dia. Close, .24" smaller
Stock rear 26.85 dia. to your rear of 26.2" dia. Not close, .65" smaller
My understanding of the active Handling is that it measures tire rotation and applies the brakes to even things out . I have no idea what tolerances the computer works on but you have made a major circumference change. Only 1/2 % smaller in the front but 2.4% smaller in the back.
Might be easier to understand if we look at the tires at 75MPH;
Front stock=980rpm Front changed=986rpm; only 6rpm diff.
Rear stock=939rpm Rear changed= 962rpm; 23rpm diff.
Maybe get a larger diameter rear OR a smaller diameter front?
Old Apr 12, 2005 | 10:56 AM
smdio's Avatar
smdio
had the car for 6 weeks, 640 miles, no problems like that at all
Old Apr 12, 2005 | 11:16 AM
CDH76's Avatar
CDH76
Just curious, why did you have to pay $800 for a car that is under warranty?
Old Apr 12, 2005 | 11:50 AM
vrodder64's Avatar
vrodder64
Then why would the problem start after 2300 miles of driving. If the diameter was too different, wouldn't the problem start right away.
Old Apr 12, 2005 | 12:17 PM
Burple_X's Avatar
Burple_X
Aftermarket wheels (Ronals) that I bought for my C5 last fall. When I bought the C6, I swapped wheels without changing sensors. No one knows why, but the C5 sensors continued to read on the C6. The only explanation GM had was the C6 stored the last readings from the original wheels and that was what was displaying. That's why I had to install new sensors and pay for them. That was "supposed" to correct the problem. It didn't!
Old Apr 12, 2005 | 12:20 PM
Burple_X's Avatar
Burple_X
Yeah, and I would also like to know why the problem is intermittant. I can't make the problem reoccur for the mechanic. I drove 200 miles Sunday and it only did it one time. That included stopping and turning the car off a couple times too. So, the same opportunity for it to happen should have been there several times.
Old Apr 12, 2005 | 11:15 PM
haljensen's Avatar
haljensen
No one knows the computer standards. Maybe it only samples after so many key turns? Or so many hours of operation (cumulative)? Maybe the difference doesn't register at certain speeds?
Old Apr 13, 2005 | 09:30 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i had this problem a couple of times, always when the roads are either wet / damp / or sandy (salted).
once i was playing with a 350z (around 75 mph) and it tripped, it started bucking wildly like a real bad miss, then the DIC said "service traction system" and my traction light came on. I had to turn the whole system off so i could continue to play.
it resets after shuting down the car.
the other time it did it when I had my girlfriend in the car and i got on it a bit from a stand still, i was pulling out from some gravel.
The workaround I use is whenever it's damp I turn off the traction control, I know that kinda defeats the purpose of having it but I don't want to leave the car at the dealer until they fireu out what the prob is.
the first time it happened I hit onstar and they told me there was something wrong with the ABS and I needed to take in in right away. I did and they couldn't find anything, since I shut off the car and it reset.....
Old Apr 13, 2005 | 11:24 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
The tire diameter difference sure sounds like it may be contributing to your problem, at least in part. Being intermittent sure makes it a lot harder to diagnose. Have you driven at speeds over 75 since it started happening? And is there anything else that you modified? Did it occur with the wheels straight or turned? I'm wondering if the tire changes are just barely significant enough to make the computer activate TC/AH at freeway speed while going aroung a slight curve.
Hope you get this figured out soon.
Old Apr 13, 2005 | 11:57 AM
EHS's Avatar
EHS
Here is a link that is a must read:
http://www.geocities.com/nosro/abs_faq/
See the section on:
What happens if I install aftermarket tires, wheels, brake linings, calipers, springs, . . . ?
Part of what it says:
"It is anybody's guess. Tires and brake linings are fairly safe items to experiment with. Having said this, I will point out that I am familiar with at least one case where the installation of high performance tires (where smooth-riding all-season tires were original equipment) resulted in a reaction with the suspension that ABS had not been tuned to anticipate. In this case, the installation of high performance tires resulted in significantly longer stopping distances because the extra tire stickiness was causing the front suspension to literally bounce off the jounce bumpers repeatedly, causing very violent changes in tire grip that ABS was not expecting. From a strictly ABS standpoint, it is best to stick with a tire, wheel, or brake lining that is similar in characteristic to the original equipment parts, or at least similar to any of the parts that are available as an option on that vehicle."
That's why OEM Z06 wheels and tires on my C5 convertible was as far as I felt I should go.
Old Apr 13, 2005 | 01:59 PM
Burple_X's Avatar
Burple_X
Originally Posted by mlongo99
The tire diameter difference sure sounds like it may be contributing to your problem, at least in part. Being intermittent sure makes it a lot harder to diagnose. Have you driven at speeds over 75 since it started happening? And is there anything else that you modified? Did it occur with the wheels straight or turned? I'm wondering if the tire changes are just barely significant enough to make the computer activate TC/AH at freeway speed while going aroung a slight curve. <snip>
I just picked the car up about an hour ago. The service tech told me that GM said not to spend any more time on the car until I put the stock tires/wheels back on the car! They "think" (maybe more accurately "guess") that the problem is coming from differences in tire circumference as previously theorized in this thread.
To answer your questions... Both times it has done this (1) I was on perfectly dry, flat road (interstate 77), (2) I was rolling down the road in a straight line at a constant speed and (3) I was not horsing around spinning tires, swerving, etc... Each time I was running just over 70mph. Both times when the Traction System Active warning came on, the car slowed to 70mph and would not accelerate past 70. Both times, I hit the traction control button to turn off the system and everything went back to normal.. except no traction control.
I am going to put the stock tires/wheels on the car before we head over to Bowling Green next Thursday. If it does it again, atleast I will be headed in the right direction for some answers!... maybe!!
Old Apr 13, 2005 | 02:04 PM
Burple_X's Avatar
Burple_X
Good article, but so far my ABS hasn't been effected.. or atleast I haven't had the opportunity to test it. I would like to get all this sorted out though before I sign up for track days somewhere. Nothing worse than going to the track and working on your new car!
Old Apr 13, 2005 | 02:59 PM
vrodder64's Avatar
vrodder64
F55, Z51, or base suspension?
Old Apr 13, 2005 | 07:35 PM
haljensen's Avatar
haljensen
Interesting site for wheel/tire sizes.
http://gs.tolan-hoechst.com/tirecalc.htm
Old Apr 13, 2005 | 08:08 PM
Burple_X's Avatar
Burple_X
Z51
To Traction System Problem
