Computer Changes On C6 Gear Change
Old Apr 20, 2005 | 10:02 PM
patriot's Avatar
patriot
Default Computer Changes On C6 Gear Change
Does anyone know what has to be done to the computer in the C6 in order to do a gear change? I have an automatic with the 3.15 axle and want to put in a 3.90. I know the speedo doesn't need to be recalibrated, but what about shift points. Is Ls2 edit needed to do this or can a performance shop just reflash the computer with a handheld or tech 2 etc?
Old Apr 20, 2005 | 11:03 PM
blue racer c6's Avatar
blue racer c6
If you have lpe do gear change they will reprogram . I have 500 hp head and came from lpe and same gear but they change shift points, I still might have them change gear to 3.42 ask for jeff.
Old Apr 20, 2005 | 11:04 PM
blue racer c6
If you have lpe do gear change they will reprogram . I have 500 hp head and cam from lpe and same gear but they change shift points, I still might have them change gear to 3.42 ask for jeff.
To Computer Changes On C6 Gear Change
