Need Modification opinion!!
Old May 11, 2005 | 08:59 PM
Trance Guru's Avatar
Trance Guru
Default Need Modification opinion!!
Ok guys, I'm 3 weeks away from the arrival of DSOM C6. I have some minor mods on the way....so far on order....
LG Long Tubes
Black competition wheels from Corvette of Houston
Pro-charger (GT Automotive in Mississauga)
Lowering...
Here is where I need help...?
I am thinking of a cam. Can anyone suggest a cam that isn't to aggressive for city driving?
And Exhaust (I know this is beat'n to pulp already), BB, Corsa or GHL?
Thanks...
Old May 11, 2005 | 11:33 PM
smdio's Avatar
smdio
B&B Bullets exhaust system
dynatech supermaxx headers w/ x-pipe
5% window tint
ZAINO ZAINO ZAINO !
Old May 11, 2005 | 11:59 PM
SpinMonster's Avatar
SpinMonster
LG Long Tubes
Lowering...
Thanks...
If you are installing a procharger then you wont get anywhere near the cam specs that would affect city driving since overlap of a big cam would blled off boost. Stay with a 220/224 115 lsa with as much lift as your spings can handle.
Exhaust is a waste of money if you are looking for more power. Wait till you hear how the car sounds with the above mods.
Good luck with the car.
Old May 12, 2005 | 12:15 AM
SA734's Avatar
SA734
Check the C6 FAQ Section for lowering threads, all info there. I did Corsa Sports, very happy.
Old May 12, 2005 | 01:11 AM
SpinMonster
I lowered my car but not that much. I have to compliment your slammed ride....looks awesome
Old May 12, 2005 | 06:19 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
what ??? nothing like have a powerful engine corked by the exhaust. agreed, build the mods. then select the exhaust and headers for the combo.
Old May 12, 2005 | 09:49 AM
dshaner1's Avatar
dshaner1
I would have a custom blower cam made to spec....if you get one thats off the shelf make sure you get the right blower cam tfor what your needs are....most places that sell these should be able to help you with that choice.
Also, I would check and see what cams some of the Zo6 guys with blowers are running and use those as a guideline.
If you are going with a pretty aggressive set up, go bullets. I would bet you'll get 10 horse more out of that over any other system when you go FI.
Old May 12, 2005 | 10:02 AM
Fredo's Avatar
Fredo
Kooks, Magnaflows, 160 thermosts and tuning will put you near 390 rwhp. Chrome the wheeks and you are done.
Old May 12, 2005 | 12:54 PM
andreas g.'s Avatar
andreas g.
Default Blowers not working on these LS2 motors yet
First thing is to much static compression 10.9. Your boost would be so low it's not going to make any real power. You would have to lower your compression a bunch. Then it should work. And right now only LPE and probably Z-industries can make the PCM work under boost conditions and LPE only tunes in house with one of there packages. So your limited. Secondly, with bolt ons and tunning Fredo and myself are making near 390RWHP, add a cam say 222/224 on 115 LSA and lift in the 580's and an under drive pully,and your looking at 430RWHP. That's 500 plus flywheel HP. On the street that's walking with the heavy hitters. My C5 made 500 flywheel HP so I have a clue of just how much that really is on the street. (my son has the car now). Yea there are some cars with more but there not daily drivers, not really streetable, and with the tires we have you could never really put it to the ground and hook up anyway. So be somewhat conserative and you'll have a really fast car you can drive everyday with no worries.
Andy G
Old May 12, 2005 | 01:39 PM
SpinMonster
Originally Posted by andreas g.
First thing is to much static compression 10.9. Your boost would be so low it's not going to make any real power. You would have to lower your compression a bunch. Then it should work. And right now only LPE and probably Z-industries can make the PCM work under boost conditions and LPE only tunes in house with one of there packages. So your limited. :
So East Coast Supercharging, Cartek, A&A corvettes, and MTI can't tune forced induction cars? Andy at A&A and Cartek definitely have the beta version of LS2 edit. Wow I thought that was what some of them specialize in. Where did you get this info from?
Old May 12, 2005 | 01:42 PM
SpinMonster
So corked that it only gives you a whopping 10 flywheel HP for the 1200 bucks you drop to make your car louder. The stock exhaust happens to be very free flowing. One guiy got 4hp at the wheels.
I said it is a waste of money if you are doing it for power....still my opinion
Old May 12, 2005 | 01:59 PM
andreas g.'s Avatar
andreas g.
Default The info on blowers
the info came from Ron Zimmer at Z industries and graham at LPE a couple of months ago,they have a clue about tunning. By now I'm sure some people can and some people think they can tune blown motors. The last time I talked to Andy at A&A his LS2 edit wasn't even working. I'm going down to Ron's today for some additional tunning. Fan controls, cags, and some more TM he just found in a very interesting place. He said it's worth 1/2 sec. I'll ask him today about who's tunning blown motors now with success, and get back to you on friday. BTW how many people with blown C6's are talking about them on this forum?
Andy G.
Old May 12, 2005 | 02:47 PM
Zig's Avatar
Zig
i'm not saying that is the only mod you should do, but rather one of the last ones, when the exhaust becomes the choke point. get the engine running more efficient and you will have to change the exhaust as well as the exhaust manifolds in order to get the most from it.
Old May 12, 2005 | 05:48 PM
AutoCutter's Avatar
AutoCutter
CraneCam Quick Ratio 1.8 Rockers, lifters, & springs
FAST 90mm LS Intake Manifold
34 or 35lb Injectors, balanced and blueprinted (RC Engineering)
If you have any leftover cash
LS6 Exhaust Manifold
Corsa Sports
Old May 12, 2005 | 07:28 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Borla Stingers
Get a cam from either CARTECK or Lingenfelter. Forget the high lift rockers - last reported only a 10-15 HP gain
Old May 12, 2005 | 08:13 PM
Trance Guru
Thanks for the advice guys, I have lots to discuss with GT automotive. I may still see what Caravaggio in Toronto has to offer, I know his work has been outstanding in the past.
To Need Modification opinion!!
