Exhaust install - How Difficult?
Old May 13, 2005 | 10:16 AM
Whataguy's Avatar
Whataguy
Default Exhaust install - How Difficult?
Got my Borlas on order, should arrive in 3-4 weeks. I am NOT a mechanic by any means, but would like to be able to do small mods on my Vette. How difficult is it to change out your own exhaust, I do have jack and stands and beer, what else do I need or should I just get a professional to do it? Thanks guys.
Old May 13, 2005 | 10:25 AM
TAG-D IT's Avatar
TAG-D IT
I did my Bullets just recently. Took about 2.5hours. Not too tough at all. It took about 1.5 hours to do the disassembly and hang the new parts and about another hour to line everything up and bolt it into place.
Old May 13, 2005 | 10:52 AM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
Easy enough - Jack up the car and put it on Jack Stands. Remove the rear wheels. Unbolt the the factory exhaust. Bolt in the Borla exhaust. Replace the rear wheels. Let 'er down off of the Jack Stands. 2 - 3 hours - with time for a cold brew.
Bill
Old May 13, 2005 | 11:20 AM
TAG-D IT's Avatar
TAG-D IT
When I did my exhaust, I didnt have to remove the rear wheels.
Old May 13, 2005 | 12:17 PM
cmb13's Avatar
cmb13
Bill
Why do you have to remove the rear wheels?
Old May 13, 2005 | 12:18 PM
VetVetter's Avatar
VetVetter
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
I did the B&B Bullets, but the method is same (and of course so are the bolts/nuts).
http://forums.corvetteforum.com/show...3&forum_id=101
Old May 13, 2005 | 02:01 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Bill
If you remove the wheels torque them back down to 100ft/lbs
Old May 13, 2005 | 02:46 PM
dollarbill's Avatar
dollarbill
It actually can be done with the wheels in place. By removing the rear wheels, it just gave me more room. And as mentioned by Ginny, if you remove 'em be sure torque 'em to 100 Ft/LBS. Bill
Old May 13, 2005 | 03:16 PM
cmb13's Avatar
cmb13
Novice question, I'm sure. How the hell do you know how much you're torque you're applying?
Old May 13, 2005 | 03:43 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Use a calibrated torque wrench, or go to a tire store and let them use theirs.
Old May 14, 2005 | 09:49 AM
Whataguy's Avatar
Whataguy
Default Thanks...I'm encouraged
Everyone makes it sound easy so I'm planning on doing it myself. Thanks for all the advice.
Oh goody, now I get to buy a calibrated torque wrench, I'll add it to my collection of Vette goodies...exhaust, jack & stands, Craftsman tool set, epoxyed garage floor, new garage cabinets, garage floormats, bra, CAGS eliminator, V1 quick connect & mount, Vette hats and full stock of Zaino. I ain't had this much fun since college.
* 22 and counting
Old May 14, 2005 | 10:00 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
* 22 and counting
don't forget to remove the rear sway bar. this will help when dropping the mufflers and putting the new ones up. plan on spending ALOT of time on your back. even with jackstands (depends on how high you put it) this car is low. if you're thin enough and you can get the car high enough you can use one of them dollys (crawler), it's basically a back sled with wheels. makes sure you use the GM connector gaskets. you need a good squish / tight connection to the H-pipe and the rest of the cat back. torque them there bolts, then after a week or so of driving, daily driving that is, crawl back under and recheck the torque on everything.
as VetVetter said, http://forums.corvetteforum.com/show...3&forum_id=101
Old May 15, 2005 | 09:51 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Had a Mech do mine. I helped. You need a lift.
Take it to Midas they'll do it for $150 or less
Old May 15, 2005 | 10:01 PM
Big Ron 77's Avatar
Big Ron 77
If you drop the sway bar, which will make life a lot easier, you can search here to make sure, but I believe the torque specs on those bolts are 65 ft-lbs for where they mount to the frame, and 44 ft-lbs where they mount to the suspension (the smaller bolts at the rod ends). Might as well use the new torque wrench a bunch!
Somebody please post better #s if these are off. Have fun, and if you get too frustrated, just drive it quietly with open headers to the nearest exhaust shop and give them $150 to fix you up.
Old May 15, 2005 | 10:17 PM
crabman's Avatar
crabman
Call me a sissie. Midas, 75 bucks, 1 hour. No hassle.
Old May 17, 2005 | 06:26 PM
SteveDoten's Avatar
SteveDoten
if anyone is in CT i may be able to help you(avon, ct)
Old May 18, 2005 | 06:12 AM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
You Sissy Let the Pros do it
To Exhaust install - How Difficult?
