Speed bleeders
Old May 27, 2005 | 11:29 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Default Speed bleeders
I'm looking to buy a set of speed bleeders. Does anyone have experience with these, and where can I find them? What features/brands should I look for or stay away from?
Old May 27, 2005 | 12:20 PM
MitchAlsup's Avatar
MitchAlsup
I like my Motive PowerBleeder. I can flush or bleed the system in about 1/2 the time it takes me to remove and reinstall the tires. Just put some fresh fluid in the drum, screw cap onto brake reservoir, pump to 5 PSI. Now go to the farthest brake caliper, attach hose to waste container, open valve, wait for fresh fluid to appear (a few seconds), close valve. Repeat on 3 other calipers.
Old May 27, 2005 | 05:00 PM
mlongo99's Avatar
mlongo99
How much $$$ does that type of setup go for? Is there any problem with acciental spillage at the master cylinder resevior?
Old May 27, 2005 | 05:07 PM
PJinNJ's Avatar
PJinNJ
Default Speedbleeders
I use them on my Jeeps, a FANTASTIC product, never thought about putting them on the Vette. But I would endorse this and do it myself.
Old May 27, 2005 | 06:35 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
i had them on my c5
They are excellent !
Old May 28, 2005 | 08:30 PM
mlongo99's Avatar
mlongo99
Where's a good place to buy? I've had a hard time finding them.
Old May 28, 2005 | 09:04 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
google "speed bleeders" for info
Old May 28, 2005 | 11:29 PM
HalM's Avatar
HalM
We run them on our race car. Great product if you get stuck running single man operations...SpeedBleeders has a website that is quite helpful...
Old May 29, 2005 | 03:42 PM
mlongo99's Avatar
mlongo99
Thanks guys! I checked out the speedbleeders website, they don't have sizes listed for vettes after 98, but I sent them an email asking what size will fit.
Old May 30, 2005 | 11:52 AM
SA734's Avatar
SA734
Mark, go to Harbor Freight or an auto parts store and pick up a Mighty Mite Vacum Brake Bleeder for $34. Simple and easy to use. Bought one when I removed the calipers for powder coating.
Old May 30, 2005 | 01:34 PM
Admiral Fairway's Avatar
Admiral Fairway
The Mighty Mite Vacumm works great, I just did my '97s brakes with it. Just used a turkey baster to remove most of the brake fluid from the master cylinder, filled with fresh brake fluid, went to the rr brake cylinder insalled the Mighty Mite Vac, pumped up to about 5 lbs vacumm, opened the bleed screw and watched as the fluid drained into the container. Repeated for other wheels all the while making sure the master cylinder stayed full. worked like a charm.
Old May 30, 2005 | 07:18 PM
mlongo99's Avatar
mlongo99
I got the sizes for the "speedbleeders" brand. If anyone wants to know PM me. Now I just need to decide which type to get. The vacuum type seems pretty easy to use. Thanks guys
To Speed bleeders
