Alignment done, big difference.
Old Jul 4, 2005 | 01:38 AM
  #41
C5stein's Avatar
0C5stein
Former Vendor
On a stock ride height C6, that amount of Camber should be fine when accompanied with that much caster. With more caster, your front wheels will actually lean into the corner, so you don't need to run as much negitive camber for optimum cornering. One thing to keep in mind is that with 8 degrees (or more) caster you will have a tendancy to overheat your power steering system on a road race course if your car doesn't have a power steering fluid cooler.
All aggressive front end alignments are a compromise. For you to get more negitive camber in the front you would nee to give up some of your positive caster.
Look up on the upper "A-arm" mounts and see if there are washers between the cross shafts and the frame of the car. If there are (like the C5 Z06) you can take them out (especially on the rear mounting point of the upper A-arm) and pick up some more negitive camber without giving up any caster. If so you will need to reset the toe.
Lowering the car will also allow more negative camber.
Old Jul 4, 2005 | 07:22 PM
  #42
LS WON's Avatar
LS WON
Default Does Wallyworld do alignments on Corvettes?
Old Jul 4, 2005 | 08:04 PM
  #43
SickRick's Avatar
SickRick
So what would the "suggested" alignment specs be for a Z51 that is "driven with spirit" on the street only?
Seems with the replacement of left/rear suspension components by the body shop, I'll be in for an alignment also. Wonder if I can get them to drop it an inch too?
Rick
Old Jul 5, 2005 | 10:09 PM
  #44
FLC6's Avatar
FLC6
Would it be bad to set my non-z51 with Z-51 sway bars to the Z51 specs?
Old Jul 5, 2005 | 11:51 PM
  #45
Bill Dearborn's Avatar
Bill Dearborn
If your car is out of alignment with less than 12K miles GM will usually pick up the cost of the alignment. Have had the dealer do special settings on my C5 several times. After one trip the alignment tech said why don't you do this yourself and save yourself some money? He then proceeded to show me how to do it at home. It is not all that hard to understand but is hard work to do at home without the alignment rack. The new racks make the job a breeze and just about anybody can do the job in an expert manner.
Bill
Old Jul 6, 2005 | 12:07 AM
  #46
FLC6's Avatar
FLC6
Anyone?
Old Jul 6, 2005 | 12:48 AM
  #47
SickRick's Avatar
SickRick
Bill
Unfortunately, 2 dealers told me 7,500 miles is the magic number for my C6. Over that is considered "normal wear and tear" (and no longer a warranty freebie)...
Rick
Old Jul 6, 2005 | 12:54 AM
  #48
sallen619's Avatar
sallen619
Rick
Old Jul 6, 2005 | 01:32 AM
  #49
C5stein's Avatar
0C5stein
Former Vendor
Anyone?
Z51 & non-Z51 alignment specs are interchangeable. Just like a C5 & C5 Z06. You can put either alignment in either car. Fact is that "Factory specs" for these cars are broad recommendations. Not a specific value for each element of the alignment. To tell a
Technician to set a car to "Z-51 specs" is still a broad stoke of the brush.
Just keep in mind that the more reserved that your driving style, the less negitive camber you wnat to run for best tire life (say - 1/4 degrees). Make sure that they set the caster the same on both sides, and make sure that they set the Camber the same on both sides. We like to run approx 1/4 less negitive camber on the rear than on the front (ie if the front camber is set at -1/2 degrees then set the rear at -1/4).
Old Jul 6, 2005 | 03:03 AM
  #50
jkonkle's Avatar
jkonkle
Go big or don't go...
I just took my C6 at 2500 miles in for adjustment and oil change at the DEALERSHIP.
asked the service manager
1. to get before/after alignement specs
2. wanted to see, touch and smell the oil that came out of the vehicle
Both were delivered on and at the time two c6 vette's were in for service and at least four C5s were getting service (1 was z06).
Code:
Before settings were:
Front Left                      Front Right
Actual   Specified              Actual    Specified
-1.0      -1.1       CAMBER      -.5      -1.1
5.9       7.3        CASTER      5.5      7.3
.13       -.05       TOE         .12       -.05
After settings
-0.5      -1.1       CAMBER      -.5      -1.1
7.0       6.5        CASTER      7.4      6.5
.06       -.05       TOE         .01      -.05
No rear alignment was done. There was no-charge for this work. I believe there is a difference between Z51 and non-Z51 alignment as the before/after specified is different for some reason. The before numbers were accurate to the link tht HalJensen posted (c6/z51 alignment specs).
Vehicle drives better and wheel is level and car rides *straight.* Steering also feels more responsive...
Joshua
Old Jul 6, 2005 | 05:21 AM
  #51
aggie88's Avatar
aggie88
Default Get it Done!!!
Since I want to set mine up for autocross at -1.5 deg, I did not even think to try the dealer for the freebie alignment.
Front Camber -1.5 deg
Front Caster 7.1 deg (could not get any more on one side)
Front Toe -.04 degL -.05 degR(total toe -.1 deg)
Rear Camber -1 deg
Rear Toe +.01 deg (total toe +.03 deg)
Most forum folks probably won't run such an aggressive alignment, but get yours done to factory specs - especially if you still can get the freebie. There is no excuse! I can tell you, the factory settings on mine were (*^$#@#-UP!
Originally the front had -.5 deg cross camber and 0.7 deg cross caster. The tech evened these both out to 0.
Orginally the rear had a -.08 deg thrust angle ...the tech evened it out to 0.
With the front cross camber and caster evened out, my car drives much better now. It tracks straighter with less "floatiness". I cannot wait to autocross it next month.
Old Nov 17, 2010 | 01:27 PM
  #52
NotEnoughToys's Avatar
NotEnoughToys
Default Taking the vette in for a alignment
Originally Posted by C5stein
Sorry I've been off-line since my cornea transplant. Nate Dogs suggestions...
...are very streetable conservative track settings that should work well in all kinds of driving and give reasonable tread wear on the street. For auto-x you will probably want more neg camber both front & rear, but this is a great place to start.
And yes these are reasonable values for a lowered C5 and C6 as well.
This is from another post.... looks like good numbers... good for z51 or regular setup. Make sure caster is dead on.
This is what I set it to:
L-front camber .... -0.8
R-front camber ... -0.8
L-front caster ... 7.9
R-front caster ... 7.9
L-front toe ... .10
R-front toe ... .10
Total front toe ... .20
L-rear camber ... -0.6
R-rear camber ... -0.6
Total rear toe ... 00.00
So these are good specs for a 2007 Z51 ??.
