Bullets on-wicked resonance
Wonder if there's anything to lessen the resonance. What part of the system is causing it-H pipe, over the axle pipe? Would using exhaust wrap on some of the tubing help?
thanks James
thanks James
i believe the noise is generated from the over the axle piece. at the top of the over piece is the resonator but imo the exhaust has already slowed/cooled and encountered pressure since it hits the angle then needs to go up.
i love to see how an under the axle or a smaller (smoother) hop would work
Initally, I DO understand why you guys want LOUD, but in the end, I just do not understand why some guys still purchase something which you KNOW, totally ruins the Corvette ownership experience..... "almost painful".................. does not sound like ANYTHING I would want to purchase.
You are not the first person to speak out against B&B Bullets, after the purchase.
There are those who do like them, but I'll bet in a few years, they will be wishing they had a bit less "drone" and a LOT less NOISE!
Personally speaking, I think you just made a major mistake in getting rid of the best non-resonance exhaust made...................
In the end................each to his/her own...............free will, it's great isn't it?
And, fortunately, we have the Corvette Forum which helps us by giving us great feedback on various prouducts.............
The Bullets are totally awesome! I have the X-pipe which helps take away some resonance and have found that the tone deepend as they got a good amount of miles on from that of the first week or so after install. The Bullets for me made the car sound the way it should, now i can be louder than a fart pipe honda. But yes the Bullets are definitely not for everyone, such as the person that posted his slight lecture above, the Bullets scare some people I have noticed, but hey thats one of the reasons I got em!
For me stock did not sound like a Corvette. After test driving other types of exhaust I installed Magnaflows and Kooks. A little more of an European sound. No drone and no interior resonence.
my 2 cents
thanks James
flag:
. If you have resonance, I doubt that an x-pipe will do a damn thing for it. And dynamat won't help either. If you like the sound then more power to you
If you don't, do not waste more money on bandaides. Use that money for a different exhaust system.
The guy who had the coupe I rode in also had a "painful" experience at certain speeds/rpms. He blames it on a bad ear caused by a lot of hunting (guns). Interestingly, his wife actually liked them, and did not sense the resonance he did (and they are both in the early 50's, as am I).
When I rode with him, at one point, he said "see that, my ears are in pain right now". Don't get me wrong, I could hear the exhaust, but they were not offensive to me (or his wife at that speed, obviously). So, it goes beyond just preference, some peoples hearing is effected differently.
Now, on to a possible fix. I had suggested once that the perfect system might be Bullets with the Corsa "touring" resonator installed in the X pipe (look it up). And I have now been told that B&B may be working on an X pipe with a resonator built into it just for this purpose. I'd call Mike at B&B and ask if they are indeed working on that.
It's not easy to admit making a wrong choice, especially after spending your hard earned money. But getting the right sound is an important part of enjoying a car like a vette.
If you don't, do not waste more money on bandaides. Use that money for a different exhaust system.I've done both with and without, the xpipe. No question, the xpipe works, for this problem/concern.
i think, i also saw that random technologies was working on a set for the c6 that has responators in the x. i think it's a complete 3 inch over the axle system from the headers or the other set is 3 inch from the stock cats.
also btw: the other folks are correct. dynamat, etc. won't really do much to get rid of the drone. only thing it really does is to tighten up specific pieces, which in turn causes a larger vibration area. this will change the cabin dynamics a bit but mostly just take it to a deeper frequency.
the problem is the c6 is airtight. you are inside a drum. wonder how it would work if the over the axle ended at the top of the axle and came out behind the rear wheels. what would it do to the paint, etc. shouldn't the exhaust flow free'er since the pipes exit would have lower pressure. the exhaust would exit the cats, flow down the x, it would then go up to the top of the axle then turn up and out so it exits right above the top right rear section of the wheel.
