Lowering Bolts Cause Noise
Old Jun 14, 2005 | 04:02 PM
Dr. Ground's Avatar
Dr. Ground
Default Lowering Bolts Cause Noise
Lowered my C-6 two months ago with WCC lowering bolts. The thin layer of rubber has worn off the bolts and causes steel to aluminum rub making a wear pattern on my lower rear A arms and makes noise. Does anybody know of a fix,maybe a nylon or urathane wear plate?
Old Jun 14, 2005 | 04:20 PM
thorkonan's Avatar
thorkonan
Zip products have lowering bushings for this problem.
Old Jun 14, 2005 | 05:05 PM
Dr. Ground's Avatar
Dr. Ground
Thank you thorkonan and the Forum, ZIPS is just what I needed.
To Lowering Bolts Cause Noise
