Column Lock...car won't start
Old Jun 26, 2005 | 12:12 PM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Default Column Lock...car won't start
I went to jump in my car this morning to pull it out to wash it. I jump in, push the button and nothing. The car tried to crank for about a second then nothing. I'm not getting the "Service Column Lock" message and the "No FOB Detected" message. I checked the battery and it's at 10 volts. I've read a couple of other threads that a low or dead battery could cause these problems. Does anyone have any ideas?
I'm a little upset and have no way of getting to work in the morning.
Old Jun 26, 2005 | 12:22 PM
6speedC6's Avatar
6speedC6
I had the same problem. Dead battery, no FOB detected and column lock message. Jump started it(battery read 5 volts) Took it in to chevy. They charged the battery and found nothing wrong. I got home and pulled out the infamous relay #46 from the fuse box next to the battery and it has been two weks and all is well.
Old Jun 26, 2005 | 12:26 PM
NavyC5's Avatar
NavyC5
Thanks. I guess I'm off Sears to get a battery charger. I think a phone call to Chevy is in order. I drove the car on Thursday and it was completely off. I'm not happy about this.
Old Jun 26, 2005 | 12:34 PM
6speedC6's Avatar
6speedC6
I bought one last week at sears. I believe it is on sale till first week of July. 50amp start and a 10 and 2 amp charge with auto shut off for 39.99
Old Jun 26, 2005 | 12:38 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've read a lot about DBS and relay #46 on the forum....while I haven't personally experienced DBS, I'll admit the discussion surrounding DBS and relay #46 were compelling enough for me to give it a shot, since my car sets in the garage a lot (not my dd). Pulled #46 out about a month ago. After 4-months of ownership, still no indications of battery problems what so ever to date. Guess time will tell.
Old Jun 26, 2005 | 01:06 PM
SINCITYC6's Avatar
SINCITYC6
What does relay #46 go to??
Old Jun 26, 2005 | 01:17 PM
Vette_DD's Avatar
Vette_DD
Headlight washer on European models.
Old Jun 26, 2005 | 01:19 PM
Kreuzen's Avatar
Kreuzen
Its actually for pop-up headlight washers that you only find on the European models. However, for some reason, the US models also have the relay installed, but as you know, without the pop-ups. Long story on the theory, but if you do a thread search you'll see various opinions on how it could possibly be linked to DBS....open circuit, blah,blah,blah.
Old Jun 26, 2005 | 05:30 PM
SickRick's Avatar
SickRick
Damn...
POP UP HEADLIGHT WASHER!!! I WANT ONE...
(not)...
Rick
Old Jun 27, 2005 | 06:49 AM
NavyC5's Avatar
NavyC5
*UPDATE*
Went down to Sears and picked up a battery charger. Did the slow charge at 2 amps for a few hours. Car cranked right up with no problems. My biggest headache is the fact that the car wasn't sitting for a period of time. I drove it Thursday. IMHO the battery should not have gone down that fast.
Old Jun 27, 2005 | 05:16 PM
6speedC6's Avatar
6speedC6
Originally Posted by NavyC5
*UPDATE*
I drove mine on a Friday then went to start it on Sunday morning and it was dead! As I stated before I jumped it took it to chevy and they didn't find anything wrong. I Pulled the 46 relay and it has been fine since!
Old Jun 28, 2005 | 06:49 AM
NavyC5's Avatar
NavyC5
I may look into doing that this weekend. If I didn't have the girlfriend's truck to get to Sears I would have been totally screwed. And not in a good way.
Old Jun 28, 2005 | 09:13 AM
StanNH's Avatar
StanNH
Whatever is causing the battery drain seems to be a very intermittent problem. Some of us have never had any battery issues at all, even under severe conditions, while others have had theirs go dead for no apparent reason. Granted, some may be caused by driver error (with the MN6/reverse situation), but certainly not all. There's also the possibility that some are related to interaction with other devices. Unfortunately, this still leaves a large number of these cases with no obvious explanation.
The #46 relay solution is interesting, but I don't believe any measured drain has ever been associated with that relay being in place. If removing the relay works, it works, but nobody seems to know why. It sure would be nice if someone would actually be able to isolate and replicate this problem...so far, no one has been able to do that.
At this point, I'm one of the lucky ones who's never experienced a dead battery. I do not have OnStar, NAV, or the XM installed. I've had the car since late October and it lives in an unheated garage in the coldest part of New England. It would be great to know why some batteries fail, but it would also be wonderful if we knew why the others didn't.
Old Jun 29, 2005 | 11:03 PM
Norske's Avatar
Norske
In at least one case, Relay #46 was implicated in higher than normal current draw: "...Total parasitic draw was 128mA. The relay was removed and the draw went down to 10mA."
See: http://forums.corvetteforum.com/showthread.php?t=996635
Old Jun 30, 2005 | 08:01 AM
NavyC5's Avatar
NavyC5
That's some good info to know. My car will be sitting from tonight until Sunday morning for a car show. I'll probably hood up my batter tester and monitor the results.
Old Jul 7, 2005 | 12:46 AM
c6buyer's Avatar
c6buyer
Default Battery Dead
I had my car sitting for maybe 5 days and went out and the battery was dead. Jumped it off with ground to engine block and it ran great. Will try the #46, while it doesn't make sense, I really don't want to get stranded. Any other thoughts or fixes anyone knows of from GM?
Old Jul 7, 2005 | 01:14 AM
sallen619's Avatar
sallen619
I've had my car for 8 months. My car sits in the garage from sunday night till friday night every week. I haven't had the problem yet. When I get out off the car, I make sure the steering column is locked.
To Column Lock...car won't start
