Relay 46 Definitive Test
Mike
Mike
Mike
About 2 weeks ago there was a thread (EDIT: Oops, this was the thread! :o) discussing the amount of current relay #46 was capable of drawing and whether it was enough to kill the battery in some period of time. I decided to hook my DVM to relay 46's coil hot side to see what kind of voltage was there. What I found (at first) was 5 volts on the hot side and, of coarse, nothing on the low side. The BCM appears to ground the low side when (if) it wants that relay to come on. I probed a couple of other relays and found a couple more with 5 volts on the coil's hot side. This was strange since you would expect 12 volts. In fact, most relays had 12 volts at their coils. I figured that the few relays that had 5 volts (including #46) were being supplied voltage by the BCM instead of the main 12 volt buss.
To see if this was the case, I waited for the BCM to go to sleep by watching when the engine compartment light went out (auto shut-off). It did, and the 5 volts I was reading at the relays dropped top zero. Then I woke the BCM again by lowereing the hood and raising it again to get the engine compartment light to go on. This time I got 10 volts on the relays instead of 5 volts. I did this a couple of more times trying different things to wak up the BCM (open the glove box, turn on the map light). Each time I got 10 volts. Why I got 5 volts the first time is unknown.
The point of this whole thing is that it appears as if *anything* wakes up the BCM, a lot of things happen, including the power-up of the underhood relay box, the Nav's DVD spins, and who knows what else...
Here's a what-if: I read that the tire pressure sensors in the wheels *each* transmit every 15 minutes when the car is at rest. If each time a wheel transmits the BCM wakes up, and the wheels dont all transmit simultainiously, does the BCM wake up (up to) 16 times an hour?
I'd be willing to bet that GM knows precisely what's going on but the fix will cost them too much $$ for now so they're staying silent.
My car is subjected to the worst storage conditions during the winter months. It's kept in an unheated garage and ambient temperature can reach 35 below zero. We can stay below zero for many days at a time. When the temperature gets over zero, I usually start the car every few days and let it run for at least 45 minutes. It has always started the first time and cranked strongly. If the temperatures get above 10 and the roads are dry, it goes out for a drive. I have kept the original Delco battery and, as yet, have found no reason to change it.
I have the 1SB, no NAV, no OnStar, no XM, manual tranny. Homelink is used for a single garage door opener only. I have not pulled relay #46.
I hope I didn't just jinx myself. Watch...tomorrow my car will be dead.
with the last statement...it's unfortunate...
