why not matched rotors ?
Old Jul 7, 2005 | 03:25 PM
robvuk's Avatar
robvuk
Originally Posted by Zig
i'm not looking for any better braking just a balanced look front and rear. i was curious if i used the same size for both front and rear if i would be inviting problems.
I believe you would be asking for trouble. At the very least, your ABS would be kicking in prematurely as it tried to keep the rears from locking up. These things can be compensated for but that would require some reengineering of the system as others above have mentioned. I wouldn't find it that important.
Get a lifesize picture of a 16" rotor and caliper and install it on the axle behind the wheel.
Old Jul 7, 2005 | 03:26 PM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
thanks.
Old Jul 7, 2005 | 03:58 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
with all this being said, would there be a problem with larger (same size as the fronts) on the rear ?
You'd be adding useless unsprung weight to your rear wheels, trading handling for supposed looks.
Old Jul 7, 2005 | 08:24 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
party pooper
Old Jul 7, 2005 | 11:30 PM
neko_cat's Avatar
neko_cat
You could add playing cards to the spokes to make the car sound better too.
-mikey
Old Jul 7, 2005 | 11:36 PM
CV62's Avatar
CV62
St. Jude Donor '05-'06-'07
Originally Posted by jschindler
I almost can't bear to see what kind of answers this is going to bring. Just too painful to watch
I need to move to a new post before I throw myself off a bridge
Old Jul 8, 2005 | 07:36 AM
Zig's Avatar
Zig
if you do jump, can i have your car, always wanted two of them, one to test mods on and one to drive.
Old Jul 8, 2005 | 09:29 AM
texas_c6's Avatar
texas_c6
Originally Posted by Wicked_C6
Yeah I just did this last weekend. I put a phone book behind the brake assembly though to catch the bullet. Worked like a charm - even mounted the bullet in a frame and hung it on my garage wall shrine.
Actually though I just used a .22 hard point - the force of impact opens the holes up a little anyways.
If only I had a dollar for every minute complaint - I could buy those Baer rotors...
Great idea using the phone book to catch the bullets, doe that mean you can re-use them? I still think I will try the cordless drill since I do not have a gun, I will post pictures and results when I finish.
Old Jul 8, 2005 | 05:22 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
Originally Posted by MarineC6
So Stop Tech's or Wilwoods 14" front/back kit is not a good idea?
I'm really wanting to do the big brake upgrade
As long as you work with a "package" that is designed for all 4 corners. Putting bigger brakes on the back only could turn your car into a front wheel drive.......sort of.
Old Jul 10, 2005 | 12:09 AM
BEZ06's Avatar
BEZ06
Originally Posted by fhellwig
Is this really true? Are the rotors a different size? I mean, the ones on the rear *look* smaller but isn't that just because the rear wheels are bigger?
On the base suspension and F55, the rotors are 12.75" in the front and 12" in the rear.
So, the rear wheels are not only bigger, but the rotors are smaller. This does give a lousy visual to the car.
The Z51 is, I believe, 13.4" in the front, and I don't know what they are in the rear, but they're larger than the base/F55.
I put the Baer EradiSpeed rotors on my F55 and it looks a lot better, especially in the rear. The front is the same size as stock (but drilled & slotted), but the rear is a 14" rotor. You get a bracket extender with the rotors to move the caliper out where it needs to be.
Click on "My Corvette Photos" to the left under my avatar to go to my gallery to see some pics (before and after) of my rotors.
Bob
Old Jul 10, 2005 | 10:29 PM
robvuk's Avatar
robvuk
Using a pre-engineered "package" is fine. The calipers are probably valved for the proper compensation. Upgrading the front AND the rear in a matched set is a lot different than upgrading the rear and not the front. If you intend to track the car, an upgraded brake package is always a nice touch and will help a lot. Money well spent. A total waste for the street unless you want it solely for the bling factor.
Good luck
Old Jul 10, 2005 | 11:24 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Base is 12", Z51 is 13". The contact patch is the same due to the same caliper.
Old Jul 11, 2005 | 12:07 PM
  #33
wwashing's Avatar
wwashing
No, there is no technical reason why the rear rotors and calipers for that matter can not be the same size as the fronts and provide a balanced look.
I think the reason that the rears are smaller is that it saves money.
Old Jul 11, 2005 | 12:36 PM
  #34
TMyers's Avatar
TMyers
Increasing the diameter of the rotor will make no difference in braking power other than slowing down heat build up. Unless you increase the clamping power or increase the surface area, i.e. larger calipers, braking will be the same.
Old Jul 11, 2005 | 01:10 PM
  #35
robvuk's Avatar
robvuk
The same clamping power on the perimeter of a larger rotor will DEFINITELY provide more negative torque and therefore more stopping sensitivity or less caliper pressure for the same stopping power, therefore spreading the heat over a larger area. The SWEPT area is also GREATER. The contact patch area remains the same with the same caliper. The larger SWEPT area allows greater negative torque AND a larger cooling surface. This is a benefit with or without larger calipers.
Old Jul 11, 2005 | 01:24 PM
  #36
TMyers's Avatar
TMyers
Opps, soory for being stupid there. The farther we move from the center the more torque we apply. Forgot that little tidbit.
Old Jul 11, 2005 | 02:24 PM
  #37
docrings1's Avatar
docrings1
C6 FAQ Master
Why can't we just put a big tailhook on it and REALLY stop the car fast? ... front and rear brakes not required: 150 to zero in about two seconds!
Works for my Tomcat!!!
To why not matched rotors ?
Old Jul 11, 2005 | 07:48 PM
  #38
BEZ06's Avatar
BEZ06
I have the 14" Baer EradiSpeeds on the back of my F55, and I have noticed no problems. I think the 'Vette braking is pretty much biased to the front anyway, and even though the torque arm is increased slightly on the rear with the bigger rotors, I doesn't seem to be enough to affect the ABS or TCS.
Anyway, it sure does look a lot better!!!!
Bob
Here's a before picture:
Here's an after picture:
Old Jul 11, 2005 | 07:54 PM
  #39
Lerxst2112's Avatar
Lerxst2112
Can't get this image out of my head: lassoing a speeding meow by the tail. You've infected me with the proposition. Now, where to find a cat?
This post might be more appropriate if I lived in Texas.
Old Jul 12, 2005 | 10:03 AM
  #40
robvuk's Avatar
robvuk
[QUOTE=beezeye]
Bob
Looks great! Probably fine for normal street driving. It's the wet and track driving I would be concerned about. Have you driven agressively in the rain yet? or on a track?
