memory seats
Old Jul 17, 2005 | 09:52 PM
vette-oholic's Avatar
vette-oholic
Default memory seats
Is there a way to get the electric drivers seat to automatically go into memory position or do you have to press "1" or "2" everytime? it automatically goes into exit position when i open the door, but doesn't go into "Drive" position.
Old Jul 17, 2005 | 10:34 PM
icedancer's Avatar
icedancer
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
yes, it is matched to your fob.
Look on the back of the fob, you will see 1 or 2
get in the car, start the car or go into accessory mode, position everything the way you want it, and hold the number down (that matches the fob) until you hear a beep.
If done correctly, everything will return to that position when the car starts with that fob nearby.
Do similar to set the exit position so everything retracts (including steering wheel) when the engine is turned off.
Or, look in the owners manual, that works well also.
Old Jul 17, 2005 | 10:51 PM
BEZ06's Avatar
BEZ06
Icedancr responded that after you set up the memory positions, all you have to do is start up the car to get it go back to the position associated with which ever fob you started the car with.
Maybe he has an automatic, and I think that's the way the automatic works.
Butt.......If you have a manual transmission, you have to push the 1 or 2 button everytime you get in to get it to go to that memory position. Also, the parking brake must be set.
With the manual transmission, you have to push the clutch in to start the car. If your exit memory position is with the seat way back, the General wants you to get in , and with the parking brake set, push the 1 or 2 button to get your seat up in driving position before you push in the clutch to start the car.
When you exit the manual transmission car, put it in reverse, pull the parking brake on, shut down the ignition, then when you open the door the seat will go to your exit memory position.
Bob
Old Jul 17, 2005 | 11:04 PM
Vette_DD's Avatar
Vette_DD
Bob
Yep, with the 6-spd, you have to press the button for driving position (while the hand brake is on). With the auto, just press the start button, don't have to have the hand brake on.
Old Jul 18, 2005 | 02:00 AM
icedancer's Avatar
icedancer
I stand corrected, I do have an automatic
Old Jul 18, 2005 | 07:28 AM
vette-oholic
Thanks for the responses. I have a MN6, so I guess it's working right.
Old Jul 19, 2005 | 02:52 AM
LS WON's Avatar
LS WON
Default This seat memory option was it a single option or in a package?
Old Jul 19, 2005 | 10:35 AM
Vette_DD's Avatar
Vette_DD
Memory seat option only comes as a part of the 1SB option package.
Old Jul 21, 2005 | 12:34 AM
robvuk's Avatar
robvuk
Bob
That sucks.
I don't have a C6 yet. Waiting for my Z06. I imagine that will have the same convoluted setup.
Old Jul 21, 2005 | 06:53 AM
jschindler's Avatar
jschindler
Originally Posted by robvuk
That sucks.
How would you like it to work on a six speed car? There is no other way. You cannot start the car without putting the clutch in - try putting the clutch in with the seat all the way back. You'll realize there is a reason it works this way.
Old Jul 21, 2005 | 03:41 PM
Guppies's Avatar
Guppies
St. Jude Donor '05-'06-'07-'14, '21
That sucks. I don't have a C6 yet. Waiting for my Z06. I imagine that will have the same convoluted setup.
Yeah, it's really, really, really difficult You gotta push a button I get exhausted just thinking about it before I get in
If you want, I will be glad to handle this task for you at the minimal charge of driving the Z06 for you (that way you won't even have to shift)
Old Jul 21, 2005 | 04:24 PM
Vette_DD's Avatar
Vette_DD
Boy, talk about being big-hearted, and no monetary charge at all. You're sure you won't get too tired pushing that button in?
Old Jul 21, 2005 | 05:46 PM
DrHarlE's Avatar
DrHarlE
Default Memory Seats?
My memory seat (6sp) loses it's memory from time to time. I set it for exit position, then set it for driving position. It will retain those settings for awhile, then it will establish a new exit position and driving position. I've had it go from being too close to not being close enough. The constant so far has been that the total travel from exit to drive remains the same, i.e. if I need 6 inches of total travel it will retain that dimension but the starting/stopping points will vary. I can also cause this to happen if I have to readjust the seating position, that is without programming the door buttons.
Anybody else have this problem?
Old Jul 21, 2005 | 05:49 PM
jschindler's Avatar
jschindler
My Covette has not done it, but my wife's Tahoe has. I just live with it. It only does it occassionally, and it has nothing to do with the "Easy Exit" feature as I have it turned off in the Tahoe. I just accept it as GM's poor quality (my fourth Tahoe - you'd think I'd learn, but my wife loves them).
Old Jul 22, 2005 | 11:17 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I call it the "get ready to launch" button! That baby slides you right into position
Old Jul 25, 2005 | 04:38 AM
neko_cat's Avatar
neko_cat
How about as soon as I get in the car and close the door it moves to the sensed fob position before I start the engine?
-mikey
Old Jul 25, 2005 | 07:53 AM
SickRick's Avatar
SickRick
-mikey
And crushes your 6'7" mechanic. There's alot of things about the C6 that make no sense at all. For an MN6, this is one of the few things that DO make sense...
Rick
To memory seats
