LS2 tuning software update
Datalogger will be here today.
The idle tables will be in the latest beta do you have the update? Mostly idle transition and a few more ..... I am in a real hurry here sorry going to be late for an appointment.
Thank you
Jeremy Formato
How effective is engine tuning when you get shipped the computer vs. tuning the car on site? Would it not be much more effective to tune the car on site? Or is the difference between tuning a car on site and tuning per a list of installed mods roughly negligible?
Mike
"The accelerator pedal in C5 would be an anachronism. The Gen III would use ETC, electronic throttle control. The driver might think that his right foot was going pedal-to-the-metal, but ETC would be in the way....The computer would decide whether to obey, and sometimes it wouldn't"
Thanks,
Mike
Torque management mainly comes in during shifts and is limited to those torque levels "during shifts", it becomes more noticeable when there is allot of traction like at the track with drag radials, etc. The available LS2 tuning software that is out there and including LS2_edit (what we use) only has some of the TQ management tables that GM has in the C6.
Here are some tables found in a stock M6 C6.
"LS2 Edit Dump of Table -- 1st Gear Torque Limit - Ft. Lbs.
Filename = C:\LS2_edit\C6\2005\C6_b.LS2
500 600 700 800 900 1200 1500 2000 3000
Foot Pounds 85 89 104 111 126 148 185 244 281
"LS2 Edit Dump of Table -- 2nd Gear Torque Limit - Ft. Lbs.
"LS2 Edit Dump of Table -- 3rd Gear Torque Limit - Ft. Lbs.
"LS2 Edit Dump of Table -- 4th Gear Torque Limit - Ft. Lbs.
"LS2 Edit Dump of Table -- 5th Gear Torque Limit - Ft. Lbs.
"LS2 Edit Dump of Table -- 6th Gear Torque Limit - Ft. Lbs.
Increasing the values of these tables and other tables in the software does not completely disable torque management. Case in point, our own M6 C6 would not have been able to go 10.94 @ 127+ MPH (it was the first C6 in the 10s and if I'm not mistaken it is still the quickest C6 out there even against nitrous, blowers and strokers) if it didn't have our torque management elimination module, when we shut it off the car only goes mid 11s.
HTH, Julio
HTH, Julio
im wondering why you couldnt just "program" it out through the software (LS2 Edit, HP Tuners, etc.)? is it because these certain parameters arent available to change yet? I believe that there are more than just one area of TQ management but these software developers should be able to access them by now, especially knowing that this is the one main area most people are interested in. Hopefully the LS2 version of HP Tuners will have more to offer than the current version of LS2 Edit.
TM use to be only in A4 cars but I am a firm believer that the M6 C6 has it. Once it is gone their is a night and day difference. TM does not enrichen the mix it takes away throttle position and retards timing.
Jeremy
AFAIK the tables in the ECM aren't labeled from the factory. The labels are being supplied by the third party tuning software companies who've attempted to reverse engineer the ECM code. I have to wonder whether these labels are well chosen. Perhaps the intended function of this table is somewhat different than we think. Perhaps the "torque values" being reported by the third party software are something else as well. Your note that they don't match measured torque very well would seem to indicate that to be the case. I'd really like to see this engine on a water brake dyno so we could clearly separate steady state and transient behaviors.
Julio
I personally believe TM exists in M6 cars based on my track experience. I gained .4 in the 1/8 mile by turning off BOTH TC and AH. Not saying that I know for sure it turns off TM some how but the difference was siginificant and the launches were identical other than the car falling on it's face off the line for a second if you didn't turn both TC and AH off. None of my runs had TC on.
I honestly believe that the car uses calculations similar to those that allow a GTech meter to function. (Remember, the car has a built in G-Meter, just look at your HUD). My theory in my case was that the car actually took my MPH (0 initially off the line) and compared that against the amount of G's being pulled and used that to detect the hard launch (at least the attempt) and backed off power to the engine. It was VERY noticeable. You can even see it falling on its face in the vid. After turning off both TC and AH it ran .4 quicker.
Also, what about the claims that people have had that the car runs much better after say 3000 miles or so. Makes sense. GM making sure you break the car it and don't beat it to death till everything is settled in. Just a thought.
I still say these cars are much smarter than we imagine.
Mike
Yes Mailorder tuning is not as good as being there. We do have a good deal of experience and a very large library of files that have been dynotuned. For the most part I would say that our mail orders are 90% If we have an exact match for the parts used I would say 95%. The C6s so far are all VERY alike and that makes my job more consistent in power and setup. Also there are only a few different producers of components and I have tuned most of them. I do not have all the answers and am far from perfect, but I am very confident in tuning the C6s that we will make good power and it will be hard for anyone else to pull more power out of it.
The tables involving TM are being identified currently and dealt with. Not an easy solution but will be figured out as more information is revealed.
Shopdog you are a sharp dude. The values in the PCM are the stk values not inaccurate. When I first saw TM it was on an 01 vette and that was event I described. We were in 3rd gear in an A4 car the event lasted over 3sec under 100%TPS. Detonation isnt as frequent as you might think. They do not knock much from what I have seen at all. I do not believe that TM was designed to deter detonantion, I believe it was to make the drivetrain last. Imagine the TQ curve, now where you would have a hill you would have a plateau because the lack of TPS has taken out your peak TQ. I never said anything about the car breathing best @ 72% TPS I did say 4800RPM (peak TQ) .
And yes these cars are quite smart.
God Bless
Jeremy Formato
Sure thing, just email Dave at davebusch@cartek.net or call 908-317-4496 Monday-Friday 9:30 am- 6:00 pm EST.
Julio
However on my C6 (MN6) I would be more interested in just squeezing more juice out through tuning, especially ridding it of the TM that is always being debated as to whether it does really exist (I'm sure it does).
I wouldn't want to (drastically) affect drivability or mileage, but when it goes WOT, I don't want to leave anything on the table. What do you think?
Thx.
BTW tuning is only going to help driveability not harm it, when executed properly. You should be able to inc MPG when timing is added in the mid cruising RPMs and when the fuel trims are lined up.
Jeremy
Jeremy
I believe you to be a competent tuner and I look forward to having you do a tune for me within the next couple of weeks....albeit only if I decide against moving into a Z06.....stay tuned (pun intended!
HTH, Julio
i suspect that these tables are the "reduced engine power" table and not "torque management tables".
when was the last time you saw a car with 281 ft lbs of trq do 0-60 in 5 seconds or the 1/4 mile in 13 ?
i understand the discussion has focused on this being a "transient" behavior but i suspect this is incorrect. it makes more sense that this is actually the "reduced engine power" part of the program.
by programming these tables so the supposed "torque management" is outside the range would in essence allow one to blow his engine when/if it overheated or another fault was detected that would normally send it into reduced power.
i believe folks are making more of the black helicopter torque management than is actually there. i believe the only time torque management comes into play is when traction control is active. think about it. what actually happens when traction control activates ? doesn't it sound an awful lot like torque management ?
just my .02 cents. would love to get my hands on ls2 edit and take a look for myself.
... Traction control initiates individual wheel braking and/or engine torque reduction after sensing excessive wheelspin."
http://www.seriouswheels.com/top-200...orvette-C6.htm
