Has anyone put Speedbleeders or a comparable product on their C6? If so, could you let us know product number, where obtained, etc.? I e-mailed speedbleeders about availability but haven't received a reply.
What's a "Speedbleeder", sounds counterproductive?
Rich
I think it's a caliper bleed valve with a spring-loaded check ball in the passage. The check ball keeps air from coming back into the caliper when you're not pushing down on the brake pedal...they're supposed to allow one person bleeding.
Caliper bleed valves are generic...if you can find a "Speedbleeder" for a C4 or a C5, then it'll probably fit a C6. Just confirm the thread size is the same.
And there is also the Motive PowerBleeder. Looks like a 3 gallon jug used to spray incecticide on plants, but takes a pint of brake fluid and gets pumped up to 5 PSI after being attached to the brake reservoir. Then you walk around the car, remove the tires, open the bleeding valve and the old fluid flows out into a catch can. When you get clera fluid, close and proceede to the next brake caliper.
Works great, on person can bleed a car at the track in 10 minutes, 7 of which is jacking and tire removal.
I agree...pressure bleeding is the way to go, and the Motive PowerBleeder is not expensive. I need to get me one.
The problem with "speedbleeders" or regular bleed valves, is that air can leak in around the threads when the valve is loosened, making it more difficult to get all the air out of the caliper. This is particularly evident when you are "vaccum bleeding"...you can pump that vaccum pump forever, and you will always have a stream of bubbles coming out with the fluid.
I have not checked the location of the bleed valves on my C6, but on my Boxster I can bleed the brakes without removing the wheels, i.e. bleed valves can be easily reached through wheels. Is that possible on the C6? There seems to be a lot of room between those wheel spokes. I would check it now but the car is not handy. Anyone ever tried it?
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Use teflon tape on the bleed screws. Works great at keeping air from leaking around the threads. Mine are taped and it made a world of difference.
