Gears for my Auto
Old Aug 5, 2005 | 09:47 PM
FLC6's Avatar
FLC6
Default Gears for my Auto
Can anyone help me out with this?
I have 3.15 right now. What do you recommend? I drive this car daily.
How much will it improve my 1/4?
How much will it cost to buy and install them? I'm thinking about doing it at HP sales in Pompano.
Old Aug 6, 2005 | 12:31 AM
catpat8000's Avatar
catpat8000
For what it's worth, here are the result of some simulations.
Don't get too carried away that the times/trap speeds
might not match what you've run - the simulation
assumes some very specific weights, temp, humidity,
traction, etc which might not match your conditions.
The simulation does probably give a good hint as to
the change in et you'd see with a gear change
because that was the only variable changed in each of
the simulated runs.
Stock 3.15:1 rear:
1st @ 6500 rpm: 52mph
2nd@ 6500 rpm: 98mph
3rd @ 6500 rpm: 161mph
1/4: 12.8 @ 109mph
3.42:1 rear:
1st @ 6500 rpm: 48mph
2nd@ 6500 rpm: 90mph
3rd @ 6500 rpm: 148mph
1/4: 12.7 @ 110mph
3.73:1 rear:
1st @ 6500 rpm: 44mph
2nd@ 6500 rpm: 82mph
3rd @ 6500 rpm: 136mph
1/4: 12.7 @ 111mph
Pat
Old Aug 6, 2005 | 03:14 PM
drrichie's Avatar
drrichie
If you are getting 12.5 in the q. with a non-Z51 auto in virtually stock form your doing very well. Please don't tell me it was hot and humid in FL that day what was your 60' time?
Rich
Old Aug 6, 2005 | 03:24 PM
SpinMonster's Avatar
SpinMonster
3.73 and you will raise the rev limiter once you get the heads done raising your top speed in each gear.
Old Aug 6, 2005 | 03:59 PM
FLC6's Avatar
FLC6
I have the 3.15 axle.
I have run over a dozen 12.5's. 60 foots are around 1.95 or so.
James
Old Aug 6, 2005 | 04:46 PM
The Garage Master's Avatar
The Garage Master
James
12.5's with the juice?
Old Aug 6, 2005 | 10:43 PM
purple heart's Avatar
purple heart
Can someone show me the same comparison starting with the 2:73 axle ratio with A4 trans? I'm debating whether or not to change out the gears-I hear I'll have to buy a complete carrier to do so; from Chevy, it retails for about $23-2500, plus labor...oh, and although I've never clocked the base 1/4 mile times with the car, I have now installed a Calloway Honker Air Breather and the Corsa Sport Exhaust system. Haven't gone over 60 MPH yet as the car has only 427 miles on it(no pun there).
Old Aug 6, 2005 | 10:49 PM
FLC6's Avatar
FLC6
Chad,
Check out my sig below. Come to Palm Beach and lets go to Moroso!
Drag racing is awsome!
Old Aug 7, 2005 | 12:57 AM
Cookee's Avatar
Cookee
Going from 3.15 to 3.73 will you reduce your 1/4 mile times between .25 to .35 depending on your traction/launch.
Old Aug 7, 2005 | 01:57 AM
catpat8000's Avatar
catpat8000
If you're going to do that, why not just get a new
rear end from DTE. You can get any gear you want
and it's under $2K.
My plan is to get a 3.90 DTE rear end sometime later
this fall.
Pat
To Gears for my Auto
