Stock Dyno Run
Old Aug 14, 2005 | 11:03 AM
C7Z51's Avatar
C7Z51
From: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
St. Jude Donor '05
Default Stock Dyno Run
This is a dyno run of my stock C6. The only thing i have installed on this car is a clear bra and changed the wheels to the C6R's. I don't think those modifications would add any horsepower(maybe a little torque though) . As you can tell it was about 100 degree's outside and humidty was around 17%. Does anybody out there know anything about a dyno sheet? Does my car look about average? Thanks for any input.
The first run is done in 4th gear
The second run is in 4th gear
The third run is done in 3rd gear(an experiment)
Old Aug 14, 2005 | 11:13 AM
jimman's Avatar
jimman
that's about right......Is that humidity correct for Florida??
Old Aug 14, 2005 | 11:22 AM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Its never been less than 75-80% at this time of the year...............
Craig
Lakeland, Fl
Old Aug 14, 2005 | 12:13 PM
billywallstreet73's Avatar
billywallstreet73
mine did 333 with bullets,6spd and 3k miles in south fl.Everyone the day I went had really bad numbers.Your nbrs are pretty good for stock depending on how many miles your car has.17%humidity doesnt seem right though.Every dyno is different so ,just use them for a baseline for future mods.There was one 6spd when I went that only got 318rwhp so you should feel good.
Old Aug 14, 2005 | 03:23 PM
C7Z51's Avatar
C7Z51
St. Jude Donor '05
I've never had my car dynoed before so I thought that the fan had an effect on the humidity somehow but I really didn't think it did anything. I guess their mechanism for testing the humidity isn't working properly, at the very least the humidty should have been 60%. If you check on weather.com it has the relative humidty. The temperature was correct though.
Old Aug 14, 2005 | 03:25 PM
C7Z51's Avatar
C7Z51
St. Jude Donor '05
Maybe it was the dyno you guys were on(or the one I was on)? You should have been able to get better numbers. I'm glad I have good numbers though.
Old Aug 15, 2005 | 01:05 PM
Fasterproms's Avatar
0Fasterproms
Former Vendor
That is about average power nothing to worry about there. I have often seen the same thing on the humidity and temp. I know the humidity is higher than what it is showing and the temp should be about right.
Jeremy Formato
To Stock Dyno Run
