Z51 Caliper bracket torque spec?
Old Aug 23, 2005 | 12:35 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Default Z51 Caliper bracket torque spec?
Just as the title states I need the torque specs for the Z51 caliper brackets and any other useful info related to changing out the base rotors for the Z51 rotors.Is it necessary to change to the Z51 pads or can I use the pads from the base brakes I currently have?
Thanks for your help.
Old Aug 23, 2005 | 01:05 PM
C6400hp's Avatar
C6400hp
Old Aug 23, 2005 | 01:19 PM
AU N EGL's Avatar
AU N EGL
caliper to mounting braket bolts are torqued at 125 lbs.
the Z51 calipers are the same as the C5 and C6 calipers ( made by PBR in AUstralia). The Z51 calipers have a larger mounting braket to accomidate the larger front rotor.
This larger braket can be purchased from a chevy dealer.
Old Aug 23, 2005 | 01:23 PM
C6400hp's Avatar
C6400hp
Thank you.
Old Aug 24, 2005 | 08:17 AM
6speedC6's Avatar
6speedC6
Damn thats alot of torque for a caliper sure thats not the caliper mount bolts to splindle bolts ????
To Z51 Caliper bracket torque spec?
