CAGS Eliminator?
Old Sep 12, 2005 | 02:58 PM
Michrider's Avatar
Michrider
Originally Posted by cbrf4i1
what do you exact pick up at radio shack? thanks
2.2K Ohm 1/2 Watt resistor. Bend it into a U shape, push into female side of CAGS connector. Tape it up, zip tie it to the trans tab, done.
4 for .99 at the Shack.
Much more reliable than the built up CAGS eliminators, because you don't have any connections or wiring to go bad. Your putting the resistor directly into your existing harness and your done.
http://www.installuniversity.com/ins...adio_shack.htm
Old Sep 12, 2005 | 04:28 PM
SliverMeMembers's Avatar
SliverMeMembers
Sometimes, you just don't want to rev it OR shift to 4th... best mod you can do for the Vette. Easy to reverse as well.
SMM
Old Sep 12, 2005 | 04:51 PM
nowheelie's Avatar
nowheelie
I have done the radShack method, too - a couple months going strong now.
My variation is to plug the connections back together, but before doing so, have a rubber dam in between to prevent the original connection from happening. It looks fairly oem, except for the subtle zip tie keeping the plugs together.
Old Sep 12, 2005 | 07:04 PM
Black-Bullet's Avatar
Black-Bullet
Sorry i have an A4 so what does the CAGS do?? :o :o
Old Sep 13, 2005 | 07:16 AM
cbrf4i1's Avatar
cbrf4i1
thank you, sir
