Spring swap?
Old Sep 16, 2005 | 04:50 PM
Stephen B's Avatar
Stephen B
Default Spring swap?
What is the best way to take out the rear spring? Undo the inside bolts on the lower A-Arm (after marking the alignment adjustment eccentric washer to keep it somewhat aligned for drive to alignment shop), or undoing the lower ball joint at the hub? How about the front spring? This is for an install of ZO6 springs from Gene @ Fred Bean.
