L.A.P.D. hooked me up!
Old Sep 22, 2005 | 04:28 PM
prc6vette's Avatar
prc6vette
Originally Posted by billywallstreet73
Will the spacer work with my stinger intake? If so,for 60 bucks,Ill give it a try.
It would be interesting to see what Jim thinks of this device.
Old Sep 22, 2005 | 04:45 PM
billywallstreet73's Avatar
billywallstreet73
Im guessing it makes the intakes move forward more for the longer runner.Seems like it would be a problem with the stinger,moving it forward.
Old Sep 22, 2005 | 05:07 PM
Vegas Sam's Avatar
Vegas Sam
Would it work with the Honker? The airbox is in the same location and all.
I feel like the low guy, I'm making 380 w/Kooks, tune, and the Honker. Maybe I can get to 390 with the spacer.
Old Sep 22, 2005 | 05:16 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
The spacer worked fine on our C6 and we have a prototype Vararam unit on the car. It should work fine with most intake systems, although I can't say 100% for sure unless we try a spacer with every intake system available.
The Vararam unit is a front grille breather unit so it does sit between the MAF and the grille making it a front breather kit.
Shawn
Old Sep 22, 2005 | 05:55 PM
Vegas Sam's Avatar
Vegas Sam
Shawn
Do we get a discount or a cookie for being the guinea pig?
Old Sep 23, 2005 | 07:54 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Guys,
As promised, here is the dyno sheet. The first run is the way the car came in which was equipped with K&N panel filters and Magnaflow mufflers. The second run was with Kooks headers and the third run was after we installed the Vararam throttle body spacer.
Now you can really see the results.
Thanks!
Shawn
Old Sep 23, 2005 | 11:02 PM
zippin zee's Avatar
zippin zee
canyon vette,
Thanks for the kind words. We were very happy with the power you got and we are glad that you are happy with the way the car runs. We will post the dyno sheet up for all to see the before and after results.
All this WITHOUT tuning. Not bad at all. We will be able to get you even better numbers once HP Tuner is released for the C6.
Again, thank you for the kind words.
Shawn
I had my C6 tuned over a month ago with hp tuners, might want to give Keith a call.
Old Sep 24, 2005 | 04:27 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
zippin zee,
Thanks for the heads up. They keep telling us they are still testing it. I wonder if the unlimited user version is different over the single user version.
I will look into this right away.
Thanks again!
Shawn
timmp's Avatar
timmp
Default Smog legal with headers?
shawn:
Is the set up, with headers, smog compliant in CA? I'd like to go the same direction with my C6, but don't want to deal with any smog issues.
thanks!
tim
Old Sep 24, 2005 | 04:40 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Originally Posted by timmp
shawn:
thanks!
tim
timmp,
There aren't any long tube headers available currently that are smog compliant, however we have known of many C5 owners that have told us that they have passed smog in California with their long tube headers and high flow cats.
Also, with Arnold's newest smog policy, owners of new vehicles don't have to smog their cars for at least 6 years and if you sell the car within the first 4 years of purchasing it, you don't have to smog it either. I think that is why a lot of C6 owners are installing them. They probably won't have their cars 6 years down the road.
Shawn
Old Sep 24, 2005 | 06:08 PM
AintQik's Avatar
AintQik
No,no. I'm the low guy. 404 w/ Kooks, tune and CAM!
Old Sep 24, 2005 | 11:38 PM
Brabus2's Avatar
Brabus2
I have the Vararam TB spacer & Halltech Stinger and it works great for me It did push the Stinger unit about an 1/8" forward, hardly noticeable.
Old Sep 25, 2005 | 04:46 PM
  #33
timmp's Avatar
timmp
Default Install time
Shawn:
How many hours to install the headers?
t
Old Sep 25, 2005 | 04:54 PM
  #34
KGB6's Avatar
KGB6
When you say "it works great for me", what have you noticed?
Old Sep 25, 2005 | 07:11 PM
  #35
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Shawn:
t
timmp,
About 4-5 hours.
Shawn
