I checked with PBR the manufacturers of the calipers and they say mid 2006 for aftermarket availability.
That's strange. I emailed PBR last week and this is the response I got:
I have been forwarded your email by PBR in Australia for follow
thru. At this time PBR has no plan to release this caliper into the
aftermarket. If something changes I will let you know.
Regards,
David Callari
Global Parts Source, Inc.
4554 128th Ave.
Holland, MI 49424
Sounds like it won't be too long before Fred Bean gets them in. I'd be interested in knowing if you could fit the rear '06 Z06 caliper under the stock '01-04 Z06 wheel. That could make for a really cheap upgrade to a 4 piston non-floating caliper.
Hi All,
Be rest assured that we will get plenty of these kits in and we will take good care of each and every one of you. I ask that you be patient and I promise that the minute I start getting some in I will let you all know.
Hi All,
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by Gene@FredBeans
Hi All,
$1700 would be for all 4 calipers, rotors & brackets?
You know what they say - there are no stupid questions, only stupid answers. I think you are asking because 1700 sounds like a great price. Of course, if the information about the wheels is correct, that adds a little - but not the brakes fault
Hi there,
Actually, that is incorrect. It is for 4 calipers, pads!!, rotors and there are no brackets needed. Believe it or not the pads are like 400 bucks for front and rear!
Hi there,
Hi there,
Gene
Great... $100 per wheel for pads. Anyone know if these are notorious DUSTERS?
(I supposed I should really ask this in the Z06 forum)...
I just looked in my yellow pages under "plating." I started calling and found one that would do cadmium plating for $100 minimum, meaning he probably could plate many sets at once for that price.
