We've been buggin the hell out of Gene (Beans). He's probably got a dozen on backlog by now. I really hadn't planned on (make that: can't afford) any more mods for awhile.
But I'll throw this one on a CC and worry about it later. It's probably the only thing I'm really jonesing for right this minute...
Is there a difference between the C6 and Z06 master cylinder bores?
Some notes from a google search:
1. Master cylinders with bigger bores give less pedal travel, yet a firmer feeling pedal, while a smaller diameter bore will yield more pedal travel and give a softer feeling pedal.
2. To get more force/pressure at the calipers, increase the caliper bore diameter (without changing the master cylinder, or any other components). More piston area (at the wheels) equals more pressure.
That's one thing I've been wondering about...
Will the Z51 master cylinder have the capacity to run these calipers without any issues? Obviously going to SS lines is going to help also.
Hi All,
Ha-ha.. a dozen requests by now. If you guys only knew what kind of mail I've received on this!! We're about to do something big with these... I'll be selling them on the website soon. Final tally on the selling price appears to be around 1795 + shipping.
Look out, we're pre-selling them on the website very soon!
-Gene
Hi All,
-Gene
Do you know yet if wheel spacers will be needed???
Jeremy
Gene - Is all the Hoop-La Causing you to raise your Initial Offering price from $1600 to $1795??
Supply and Demand = Price$$$$
Hi there,
I said intially that it was preliminary because everyone wanted to know what our sale price might be. I initially said 1695 and have moved it to 1795 for several reasons.
If anyone knew at all, the extent I am having to go through to get an anonymous amount of kits they would ask no questions.
The going price is 2795 of the kit, so I feel the discount given for the amount of work involved is extremely reasonable!
-Gene
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Originally Posted by Gene@FredBeans
Hi All,
-Gene
I have big drilled/grooved/plated Baer Track rotors on my present car but had a problem with wheel cleaner staining the shiney rotor hats. They looked like they had corrosion spots.
I pulled all the wheels and painted the hats and exposed part of the rotor (the 1/4 inch strip that gets rusty because the pads don't rub there) with black 1200 degree header paint after a light sanding with 400 grit. Although I didn't use any rust inhibiting primer, it looks great, has lasted for 4 years and makes the wheels stand out against the black background. A cheap, effective fix.
Hi there,
-Gene
Another vendor on this forum told me on the telephone that Z06 brakes DO fit under stock C6 wheels. OK guys, which way is it????
I tried a set of stock wheel and C6 Z06 Replicas. They will not fit without spacers. By my rough measurements the spacer would need to be at least 1/2inch
Thanks to John Page at 21st Century Musclecar for letting me measure against his Z06
