First mod
Has anyone else done this?
I would NOT recommend discarding the 'rain gaurd' (that's the large cover). The front seal leaks and the filters sit in the perfect position to capture water in the air cans. The hood seal really isn't a problem when driving in the rain but it is a problem if the car SITS in the rain. It's the water run off that seaps past the hood seal.
andreas g.
Any noticable improvement fom such a set up? I am sick of hearing about the air intake debate. I got a good look at the vararam thing and its cake to make. I'm in the garage as we type, well that's not quite right, building a knock off. Only real "secret" I see is in the shape of the elbow that mates to the MAF. It seems to be a 4" pipe that was squashed to fit under the hood.
So, I'll make one for free and see if it works. I have plenty of hardware lying around from blower installs.
...the extra displacement didn't have anything to do w/ it??
I'm using a 3" to 4" transition elbow. I used the old elbow as a template to get the proper angle. Opened up the hole in the duct a tad more. Put the pipe in. I make the hole a tad smaller than the pipe so I have to carefully force it in. Since it's pressed into a smaller hole the duct squeezes it tight (helps create a seal), I then used Permatex Ultra Black to seal up the outside. I only put the "rubber seal" on the outside (didn't want anything getting sucked into the engine). The "new" elbow is gonna provide a 3.5" opening into the duct with a 4" opening coming from the filter.
The other day I looking under the car while it was running and I could not only hear but feel a little bit of suction at the front filter.
I'm not sure of any gains. It felt like it did but unfortunately I didn't bo a before dyno. The last dyno I did (at 24k miles - and after water had been ingested into the engine at around 1500 miles - that's how I learned about the water guard) I had 350rwhp and 348rwtrq (dynojet) and a good air fuel ratio (it wasn't going rich as others have seen). The car is a mn6 non-z51, no-tune.
IMO: gains will minimal when tested on a dyno. When you make a dyno run they usually have two or three fans blowing air into the front of the car. The airflow is therefore constant, which is not the same as when you are driving, when driving the airflow will constantly be increasing the faster you go.
I have driven through multiple rainstorms and haven't had any problems with water. I've driven for hours in constant drizzle and pouring rain without any problems. I go though laser car washes and no problems.
My idea about the three filters is that any air that comes in via the stock filters (warmer since it comes from the engine bay) will be mixed with the cooler air coming from the thrid filter. I'm also thinking that the third filter will actually help the 90 degree transition of the air from the stock filters. I'm thinking, two inputs from the sides, will be pulled in and up from the input from the third.
Maybe I'm wrong and didn't gain a thing (that can be proven) but it was fun tinkering.
Wouldn't cutting the top off of the factory panel filters just allow a bunch of hot air negaiting and gains?
I'm using a 3" to 4" transition elbow. I used the old elbow as a template to get the proper angle. Opened up the hole in the duct a tad more. Put the pipe in. I make the hole a tad smaller than the pipe so I have to carefully force it in. Since it's pressed into a smaller hole the duct squeezes it tight (helps create a seal), I then used "rubber type black glue" (can't remember the name - I'll dig it out in a bit and edit the post to include it) to seal up the outside. I only put the "rubber seal" on the outside (didn't want anything getting sucked into the engine). The "new" elbow is gonna provide a 3.5" opening into the duct with a 4" opening coming from the filter.
